Flared 12" sonotube attempt - Car Audio Classifieds!
Old 07-05-2014, 09:00 PM
0/11 ssssss463
Default Flared 12" sonotube attempt
Can't afford the Psychoport yet, so I attempted to replicate it using wood, sonotube and a router.
meh
Added a flare for the inside too
Still have some sanding and filling to do
Haven't decided HOW to permanently attached the tube to the wood. It is recessed into a routered groove. I thought about either fiberglass or just spreading some liquid nail type substance around it.
Ideas?
Old 07-05-2014, 09:01 PM
0/11 sssss1513
Feedback Score: 17 reviews
Glass and resin should do the trick
Old 07-05-2014, 09:04 PM
0/11 ssss31257
there's no point in flaring a 12" tube
nice try though
Old 07-05-2014, 09:05 PM
I don't know, guys have gained flaring the rear openings around their subs and opening much much larger than a 12" sono before. It all depends on what gains your looking for.
Old 07-05-2014, 09:10 PM
0/11 ssssss463
nice try though
noted.
Now why not?
Old 07-05-2014, 09:13 PM
mega fatty
0/11 sssss6008
Look at spl cars try cut a 6" pipe in 1/2 and put it along the edges
Either way it looks good so good job
I countersink the screw heads into the tube just to hold it then use liquid nails on the back side
The liquid nails holds good but not enough
Or glass it
Old 07-05-2014, 09:49 PM
Big jcc's Avatar
0/11 sssss1178
Feedback Score: 47 reviews
Gorilla glue will hold
RD D5
RD 15" heavyweight
Old 07-05-2014, 09:59 PM
That's what I would use as well. Rub the edge of the MDF with a damp towel before applying the glue. Or just spit on your finger and run it around the surface like I do.
Old 07-05-2014, 10:03 PM
fosg8freak's Avatar
0/11 sssss1113
subscribed just for ideas
Old 07-05-2014, 10:32 PM
0/11 ssss31257
Originally Posted by stssilverado View Post
noted.
Now why not?
it's extremely unlikely that the velocity of the air moving through the port will be enough to whitsle
I need a flare for my 16" sonotube, and suggestions??? Mnorwood01 General Car Audio Discussion & Questions 9 11-30-2013 07:20 PM
box build, 2 AB HD 12's, 8" sonotube jt_buck Build Logs 22 03-15-2013 07:42 PM
8" Bravox PXW SONOtube Build :) solidcrowd Build Logs 5 04-09-2011 02:50 AM
Attempt #2 at self made flared port osmith General Car Audio Discussion & Questions 14 01-10-2011 01:14 AM
First attempt at self made flared ports osmith General Car Audio Discussion & Questions 20 01-09-2011 02:49 AM
