SA-8 V2 Box Help - Car Audio Classifieds!
Old 07-07-2014, 10:40 AM
swizard98's Avatar
0/11 sssssss43
Default SA-8 V2 Box Help
So i'm looking to design/build an SQ ported box for an single SA-8 V2 D4. It will be powered by a 500 watt Alpine amp, at 2-ohms. The problem I'm running into is that Sundown's website listed recommended ported enclosure to be .5-.75 cubic feet @ 35 hz, which is great, but their google sketchup downloadable model is more in the ballpark of .85 cubic feet tuned at 30.36 hz with 14.3 in/ft of port area. That doesn't sound right at all! Any ideas?
Here's the sketchup model downloaded from sundown:
Old 07-07-2014, 11:44 AM
Haelmuscle's Avatar
0/11 sssss1819
As far as I know even big as 1cu ft. NET gets nasty and works great!
Good Luck,
Kindest Regards.
Old 07-07-2014, 12:02 PM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
anywhere between .5-1cuft is gonna work, stay in the .75 range with your power and tune accordingly to what you prefer.
Old 07-07-2014, 03:51 PM
swizard98's Avatar
0/11 sssssss43
Ok. After some searching I'm settling on .75 cu ft @ 33 hz. But I've run into a snag. I know this shouldn't bother me, but it does. What part of an L-shaped box adds to the net volume? I can't for the life of me get my pen and paper work to match with torres box calculator or RE audio's.
This is my example box, not for the SA-8's just for example. The red is the port, blue is the internal volume. I've calculated the blue area to be 1521.75 cubic inches or .88 cubic feet. But the Torres calculator says it's .93 cubic feet. Am I doing something wrong?
Old 07-08-2014, 12:49 AM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
This is my single sa8v.2 as well. Lemme know if you you want box dims...I don't mind sharing.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 07-08-2014, 03:01 AM
0/11 ssssss535
I got the same # as you, I think torres is a little funky when your port has to have a bend in a 3 common wall box. port volume calculates to .39 (.386 actually) but torres says .42
The Following User Says Thank You to chance_p For This Useful Post:
swizard98 (07-08-2014)
Old 07-08-2014, 09:15 AM
swizard98's Avatar
0/11 sssssss43
Well I did a lot of digging and unfortunately it seems like Torres has gotten a little inaccurate on port volume/net volume. Maybe its just in the case of 3 common walls. Pen and paper won't fail me, just wanted to make sure I wasn't missing some sub box wizardry (like end correction). I'm gonna try to design a box and i'll post it up here.
That box is sexy as hell. I'll send you a PM.
Old 07-08-2014, 09:18 AM
jt_buck's Avatar
don't shoot
0/11 sssss4423
I would do .75 cubes, 32 hz, 17-18 in^2 per cube. I've designed at least 100 sa 8 boxes.
The Following User Says Thank You to jt_buck For This Useful Post:
soFat! (09-06-2016)
Old 07-08-2014, 09:37 AM
swizard98's Avatar
0/11 sssssss43
That seems to be exactly where I want it. It will be on 500 watts not 600- don't know if that changes how I want it to perform. Thats why i was leaning closer to .75 than .5. I just can't believe an 8 would like to be tuned to 32! Thats amazing. Will it reach that low?
Old 07-08-2014, 09:40 AM
jt_buck's Avatar
don't shoot
0/11 sssss4423
4 of them did a 141.2 @ 28 hz in a chrysler 300. Not my box design but they will play low for an 8.
Need you guys help with box four sundown zv3 18s ported box 12k rms. Mnorwood01 (Sundown Audio) 56 04-08-2013 04:38 PM
Dave the Box Guy Sub box for 2 15's 7'^3 @ 42hz for SUV 80$ OBO New England area hispls Wiring, Electrical & Other Installation Equipment 8 05-21-2011 01:43 AM
