18" Sealed Enclosure Questions - Car Audio Classifieds!
Old 07-13-2014, 06:04 PM
fosg8freak's Avatar
0/11 sssss1113
Default 18" Sealed Enclosure Questions
Ok, so I bought a custom 18" Ssacket designed 3000 watt subwoofer from a member on here. Problem is, I just traded in my SUV for a 2014 Kia Forte Lx. I dont wanna do anything too crazy so ported is out of the question now.
We have no T/S param's for the speaker, although the last user said it should be good for sealed as well.
What do yall think I should do for airspace for an 18" sealed? I was thinking like 4-5 cubes.
What is a generic size for a 18" speaker for a sealed enclosure?
Old 07-14-2014, 08:56 AM
fosg8freak's Avatar
0/11 sssss1113
bump?
Old 07-14-2014, 12:41 PM
skinnyg's Avatar
0/11 ssssss828
sounds about right, without any tsp to to run to get an estimate, probably go as big as you can, problem you will run into is not being able to fit into the trunk opening, not having enough space in your trunk
Old 07-14-2014, 05:40 PM
Here since Day 1
0/11 ssssss678
Feedback Score: 23 reviews
add some polyfill and you will be fine
<<<ME
DO NOT BUY FROM
Trevor Nichols 1499 FM 2109 Huntington, TX 75949
Old 07-14-2014, 06:20 PM
fosg8freak's Avatar
0/11 sssss1113
Polyfill is not always a fix. It just makes the box seem larger than it really is. If the box is already too big, I dont wanna make it even bigger. :P I just need to know a general size I should try for before I gotta start worrying about polyfill or reducing airspace.
Old 07-14-2014, 06:36 PM
0/11 ssssss292
Split the diff. 4.5. If its no good try some filling. Its a crap shoot really.
Old 07-14-2014, 06:47 PM
Inferno333's Avatar
0/11 sssss3845
Feedback Score: 44 reviews
Does the driver just use the triple stack EVO motor that he used to build a ton of drivers with? 6 or 12 spoke basket?
Old 07-14-2014, 09:35 PM
fosg8freak's Avatar
0/11 sssss1113
It's a triple stack 6 spoke driver. And I dont know much about it. And I dont think the guy I bought it from knows much about it either.
Old 07-14-2014, 10:40 PM
Inferno333's Avatar
0/11 sssss3845
Yeah. It sounds exactly like the EVO motor. I've had one before. Wish I wouldn't have traded it away since they're not so common anymore.
I would just use 3.5-4 cuft and see how it is.
Old 07-15-2014, 08:44 AM
fosg8freak's Avatar
0/11 sssss1113
Wanna buy/trade for it? Being that I'm in a car, and a small one at that, I could probably benefit more from a 12" of some sort.
In the mean time, I'll probably go with 4ft and go from there. I'll build the box at my dad's while I'm on vacation next week.
Sealed enclosure help, single 8" SD-2 8 WJ_Jeepster Enclosure Discussion & Design Construction Help 1 05-11-2014 03:36 PM
Anybody use a Z.3 15" in a sealed enclosure? edouble101 (Sundown Audio) 18 08-27-2012 07:24 PM
Enclosure Build: Sealed for 12" Pioneer~Saturn Build Logs 4 01-10-2011 08:25 PM
Single 12" Sealed Enclosure Brock592 Wiring, Electrical & Other Installation Equipment 0 11-09-2010 08:07 PM
Sealed enclosure Questions/problems? BlueLude Enclosure Discussion & Design Construction Help 9 12-20-2009 10:03 PM
