4th order sub placement - Car Audio Classifieds!
Old 07-20-2014, 08:04 PM
doug118's Avatar
0/11 sssss4674
Default 4th order sub placement
I'm already bored with my current setup so I'm going to do a 4th order c-pillar in my truck. My question is, what's the best sub placement? Box is 49" wide, 36" high, and 28" deep. Port will be on top. All options are subs inverted
1. Subs on back wall
2. Subs on front wall
3. Subs on bottom
Old 07-20-2014, 08:35 PM
G00burr's Avatar
0/11 ssssss591
if the port's on top, then put subs on bottom
4th order port placement 2slow2race Enclosure Discussion & Design Construction Help 2 06-21-2013 09:15 AM
