Need help with port - Car Audio Classifieds!
Old 09-08-2009, 07:59 PM
0/11 sssssss85
Default Need help with port
ok so i have two 15s Lethal Injection D4s being shipped tomorrow and want to start the box plan to get wood tomorrow if can get the box specs down pat.
so here is what i got from Re Calculator
Box width:51
Box height:21
Top box depth:21
Bottom box depth:21
Wood thickness: 0.75
perfect cubic feet per sub at 8.5 (4 per sub)
ok so the problem comes in with the ports. I want the box tuned to 34 or 32 hz. and in Re all you can do is a side port would that be fine for this install with the two 15 sitting on there side (not up toward the roof) if so then i want a
7.5 width square port with a 3in lip. Will this trow off the placement of the subs should i do a bottom port or Areo port?
LIKE I SAID WANT TO START TOMORROW SINCE I GOT A DAY OFF WORK
Thank you AJ
Old 09-08-2009, 08:18 PM
null_void's Avatar
0/11 sssss5915
i don't see why it would be a problem being ported out the side. you can put the subs basically anywhere they'll fit on the side and adjust the port accordingly. pics help lol
Old 09-08-2009, 08:21 PM
sound_around's Avatar
0/11 sssss9691
re's calc sux man.play with win-isd its way better.
Old 09-08-2009, 09:25 PM
0/11 sssssss85
ok i cant use Win isd have no idea what am doing but you saw the specs. by sucks do think the hz reading is off or what if so can you please tell me or help me find a program that builds the box for you in 3d that is accurate. The specs i wrote are max so if you could give me an idea i would need and go with areo or side ports it would help alot
Old 09-08-2009, 09:26 PM
null_void's Avatar
0/11 sssss5915
the prob. w/ it is that it's not very customizable, it's basically the same thing diff. shapes sizes lol
Old 09-08-2009, 09:30 PM
xseveredveganx's Avatar
Chainsaw Squad
0/11 sssss3380
I'm with these guys, the RE calc is fairly obsolete.
I use this one to determine vent length. PORT Size Calculations and Formulas for WOOFER and Subwoofer BOXES The part on the top that says, "Minimum Usable Vent Diamater," is fairly inaccurate. Well, it could be accurate, but I suggest other means of finding your 'optimal' vent diamater.
I'm assuming this is going in your screennamesake, a 63 Impala?
Old 09-08-2009, 09:43 PM
0/11 sssssss85
ok this is what i want please new to all of this so have no idea what am doing. Can some one please the specs i need these box dimensions
Box width:51
Box height:21
Top box depth:21
Bottom box depth:21
i want and tuned to 34 to 32 hz need to know port size going with areo i think and what size each piece will be like re cal does
Thank you AJ
Old 09-08-2009, 09:51 PM
Chainsaw Squad
0/11 sssss3380
With those dimensions, you have an internal volume of 10.89 cubes. With that kind of air space, I'd probably run 3 6" aeros that are 16.5" long. That will put you a slightly lower than 34hz by my calculations.
I'd also fire everything rearward.
Old 09-08-2009, 10:04 PM
0/11 sssssss85
really that would leave me 3 1/2 inch between my bottom of the box and the end of the aero port is that ok? if not then what is a bigger port i can run like maybe a 10 or a 12? thanks alot man your really helping
Old 09-08-2009, 10:09 PM
0/11 sssssss85
[IMG]file:///C:/DOCUME%7E1/Dad/LOCALS%7E1/Temp/moz-screenshot.png[/IMG]
When the port isn't quite right... SomeGuyDude Enclosure Discussion & Design Construction Help 8 09-01-2009 12:50 PM
Port Gamble Car Show 2009 to Benefit Breast Cancer ~ Port Gamble WA ~ 08-29-2009 CACO's Car Show Bot Car Show Feeds 0 08-17-2009 03:00 AM
Port q's biscuit Enclosure Discussion & Design Construction Help 11 08-16-2009 10:01 PM
Port help please Team3d Enclosure Discussion & Design Construction Help 2 04-07-2009 08:23 PM
