wall and port width question - Car Audio Classifieds!
Old 07-27-2014, 02:05 AM
0/11 ssssssss9
Default wall and port width question
Ok so I'm planning to wall 2 21s in a 1999 Honda prelude, might have to go with 18s but would like to know if these 21s can work
1.with just the using the backseat area after displacement I can only get around 11.8 cubes with 2 21s,but if I built into the trunk a little bit I could get closer to 17 cubes. The trunk part would be shorter and narrower than the main part of the box though
Main:
H:35
W:53
D:21.5
Trunk:
H:13
W:30
D:up to 28"(leaves room for batts and amps
Would look like a crt tv lol
Could I build into the trunk without sacrificing quality/loudness/response? I would think only total volume matters
2. I would like to do a center port, but to do so and get enough port area my port width would have to be 7". Is this too wide or would it be fine?
Old 07-27-2014, 02:27 AM
My wall has a narrow(er) center section that extends into the trunk. I cut out the rear deck though.
No problems doing that, but keep in mind that if you do anything offset (subs on one side, port on the other) you might have loading issues between different subs depending on how it's laid out.
Seven inches of width isn't a lot, but if you have enough height to get the required in^2 of area you should be fine.
Old 07-27-2014, 02:54 AM
0/11 ssssssss9
Thats cool, don't wanna cut my rear deck out as I have an SH and it has some good resale value.
Alright so with port in center and subs on sides of it I should be fine?
Old 07-27-2014, 02:58 PM
Yes, should work very well.
Hatchback guys: To wall or not to wall; that is the question Synestersnake31 General Car Audio Discussion & Questions 36 03-05-2014 02:09 AM
Rule of thumb on width of port. davidrforbus Enclosure Discussion & Design Construction Help 24 08-03-2012 01:29 PM
Port width problems. davidrforbus General Car Audio Discussion & Questions 0 07-11-2012 11:44 AM
port vs. wall oslouie General Car Audio Discussion & Questions 12 02-21-2011 10:33 PM
