4ths/6ths in ext cabs? - Car Audio Classifieds!
Old 08-01-2014, 03:11 PM
ChevyBoy95's Avatar
You have no Declue
0/11 ssssss773
Default 4ths/6ths in ext cabs?
Some know I have a regular center ported wall, am plenty happy with it, but was entertaining the possibility of pulling the baffles, and making it a 4th. Only issue is, space. I can fit about 20 cubes back there, current box is 16 cubes.
More of what I am trying to find out is, what worked for you. Port style, ratios, tuning, port area, yada yada yada. Mind you, I would like to keep it 4 15's, which might cause issues unless I run a 1:1 4th. 6th isnt really possible unless I lessen the amount of subs.
Lastly, I will not camper it, I will not bed cover it. If something will work it will work, if not, i will scratch the idea.
Thanks for those who took the time to read that.
edit: reason being, bandwidth right now is about 32-60, would like to have 28-55, but being able to play with authority down to about 26 would be awesome. Currently working on changing a few things internally in my box to see if i can get closer to what Im looking for, and this is the plan C sort of deal if i cant.
Old 08-01-2014, 04:05 PM
Lowroll's Avatar
TEAM DC
0/11 ssssss113
I too debated doing this very same thing with my 3 15's in my S-10 ext cab. I asked someone I know quite well that's built some 4th's and was told it was not worth pursuing or trying to build which I think is wrong to say. I dont see why it wouldn't work
1997 S-10 ext cab
320a alt
All SHCA wiring
XS Power
DC 175.4 on mids
8 soundstream pro 8's and 6 mclaren mlt-2 tweets
2 DC 5.0Ks strapped at .67 pushing 3 prototype lvl5 15's with XL recones
Old 08-01-2014, 05:06 PM
SWIFT's Avatar
0/11 ssssss656
Shrink your current port some, that should lower the bandwidth to what you want. Would atleast be easy to try it before rebuilding.
2012 F250 Lariat, lifted on 22's and 35's
4 DSS Ethos 18's flat wall, 2 Ampere Audio 7500.1's
Mechman 370, 9 batteries, Rockford Punch Pro front
Team DSS / Team Ampere Audio
Old 08-01-2014, 05:38 PM
ChevyBoy95's Avatar
You have no Declue
0/11 ssssss773
have already tried, lowers bandwidth a bit, but still a heavy drop off. Im next going to shrink internal, since box is a bit on the big side.
Tags
4th, 6th, bandpass, order
Under the Seat box for NBS GM Crew Cabs. Not prefab junk! sbarber82 Wiring, Electrical & Other Installation Equipment 3 07-20-2013 01:21 PM
options for chevy/gmc ext cabs??? gary2k7 General Car Audio Discussion & Questions 7 01-13-2013 10:09 PM
pics of single sub 4ths please. hotzie General Car Audio Discussion & Questions 53 01-05-2013 06:01 PM
Any advice for close ratio 6ths? SPLEclipse Enclosure Discussion & Design Construction Help 7 10-22-2012 09:47 PM
are ext cabs good for loudness? michael707 Off Topic Chat 24 12-21-2009 06:18 AM
