from 6" to 8" - Car Audio Classifieds!
Old 08-07-2014, 12:20 AM
ridintwo6s's Avatar
0/11 sssss1791
Default from 6" to 8"
Ok so I'm pretty sure I already know the answer to this buti just want some other opinions.
10.5 or so cubes net, currently has 2 full length 6" aeros. Moves TONS of air a day does a semi decent number with relatively low power. Was originally designed for 3 but had a slight change of plans.
With the 2 6" we have roughly 5 square per cube, with the 8" ones we will have roughly 10 square per cube and tuning is bumped to 33 hz.
Should SPL increase? If so by how much (estimate)? Will the lows still be as pronounced? Will it move more air? This is assuming everything else stays the same.
2013: 4 12s no wall mid 50s
Team HateD
Team Sundown
129.9 SBN 2013 Champ
Old 08-07-2014, 01:37 AM
KickinBlazer's Avatar
0/11 sssss1122
1 went from 8.50 square inches per sube to 11.9 square inches per cube with a single 6 inch aero and that gave me a all around gain...all tho it it did suffer a little bit on the upper frequencies 55hz and up...but anything below that is game on...and tuning was 33 but could dig down to 26hz...and in your aplication i assume the aero's are facing back? useing the rear gate to load on right?....if you are loading off rear gate will actually lower the tune as well..
if its to loud your to old!
Old 08-07-2014, 01:51 AM
ridintwo6s's Avatar
0/11 sssss1791
no this is for the 2010 Camaro i walled a few weeks ago.
original plan was 3 6" but i thought they were 8.25 outer diamter when they are 9.25 outer diamter so ended up not having enough physical space.
so we went with 2 6" temporarily, tuned @ 25 hz.
going to the 2 8" now.
Team HateD
Team Sundown
Old 08-07-2014, 01:53 AM
ridintwo6s's Avatar
0/11 sssss1791
Team HateD
Team Sundown
Old 08-07-2014, 02:36 AM
0/11 sssss1122
but yea swap um to 2 8 inchers and you should be good
Old 08-08-2014, 10:10 PM
ridintwo6s's Avatar
0/11 sssss1791
also anyone have any good information on motor force vs port area?
Team HateD
Team Sundown
Old 08-08-2014, 10:14 PM
0/11 sssss1122
Yea choose port area over motor force but it never hurts to have both
Old 08-11-2014, 04:28 PM
Lowroll's Avatar
TEAM DC
0/11 ssssss113
Just this past weekend I swapped my ports, I originally had 2 octo ports that were equal to a 7.3" aero. 9.29 per cube. absolute best I could get out of it was a 156.91 at 43hz. tuned to around 35-36 and lacked low end
So I swapped to 8" sonotubes with only 1 flared end because the lower flare would hit my motors, tuned to 32 hz, it currently plays 26-52 equally as violent and im burping a 56.8 at 44. Once I start shortening up some ports I should see much better numbers. also my voltage went up .6v at full tilt after the swap
1997 S-10 ext cab
320a alt
All SHCA wiring
XS Power
DC 175.4 on mids
8 soundstream pro 8's and 6 mclaren mlt-2 tweets
2 DC 5.0Ks strapped at .67 pushing 3 prototype lvl5 15's with XL recones
Old 08-11-2014, 04:43 PM
0/11 sssss2094
Good for you. Keep on testing and get some better results. ps. tread heading, from 6 to 8 inches, sounds like you are proud of something else
The Following User Says Thank You to jackson81 For This Useful Post:
ridintwo6s (08-11-2014)
Car Audio Bracelets!! "Bass Head" on front and "Im louder than you!" on back. g6ryder Miscellaneous Stuff For Sale 138 04-22-2013 05:27 PM
WTT variuos items for cheaper 8"/6.5" mid bass and 5.25"/4" coaxial speakers jjffy6 Car Audio Trader (WTT) 23 05-22-2012 09:04 PM
[SOLD]2 Digital Designs 9510 "F"'s with G Parts CF Dual 1.4 aluminum "Z" coils. JustinWhitty 10" Subwoofers 15 07-01-2011 07:13 AM
Mid/Tweeter "cups"/"covers"/"enclosure"/"etc"??? oxsign General Car Audio Discussion & Questions 11 04-21-2010 04:29 PM
