Little help with angles? - Car Audio Classifieds!
Old 08-08-2014, 10:07 PM
jhg33k's Avatar
n00b looking to learn...
0/11 sssss1531
Feedback Score: 31 reviews
Default Little help with angles?
Had a box designed for me for a fun, musical build. I'm building tomorrow but looking over the plans, I'm having trouble on the port pieces and what angle to cut the long edges at. This info wasn't given in the prints and he's busy right now so I haven't rec'd a response back yet. So each of the 6 pieces of port material has a beveled edge. I need to know what angle to set my saw blade at to make this properly fit together.
Here are the pics I have that should be the most helpful. I was never good at math, nor geometry so I'm in need of some help to get this done tomorrow lol!
Thanks in advance everyone!!!
|2011 Toyota Carolla S |2 Mmats HD4000.1's | Pair DC XL 12's w/AR cones | Average headrest score out of the trunk...will update after world finals
Old 08-08-2014, 10:29 PM
0/11 ssssss275
If you are doing miter cuts, all 30's I believe
Old 08-08-2014, 10:45 PM
jhg33k's Avatar
0/11 sssss1531
Will all be done on a table saw. But the GF and I were thinking 30's as well. As I said before though, since I'm not good in this area, I figured I'd get some help. Thanks!
Old 08-08-2014, 11:39 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7526
Feedback Score: 22 reviews
protracctor affter you trace it on wood
Old 08-09-2014, 12:03 AM
If you add all of the internal angles of any continuous piece together you get 360 degrees. 360 degrees/6 sides =60 degrees/2 adjoining pieces per angle = 30 degree cuts. You can use the Pythagorean formula and a little algebra to determine the lengths of each piece if you don't have those either.
The Following 2 Users Say Thank You to SPLEclipse For This Useful Post:
jhg33k (08-09-2014), ridintwo6s (08-09-2014)
Old 08-09-2014, 12:20 AM
0/11 ssssss463
let me see if I can draw up a cut sheet
The Following User Says Thank You to stssilverado For This Useful Post:
jhg33k (08-09-2014)
Old 08-09-2014, 07:00 AM
jhg33k's Avatar
0/11 sssss1531
Thanks all of you...that is exactly what I was looking for! I was dumbfounded last night and didn't think I'd be making this port lol. Was about to just substitute some sono and hand made flares if I couldn't figure it out. Much appreciated guys!!
Old 08-13-2014, 09:07 PM
jhg33k's Avatar
0/11 sssss1531
Wanted to say thanks again, guys! Got the port built yesterday Still have to round it over, smooth out the screw holes inside, and a few other things but it's pretty much done! Couldn't have done it without ya lol
How crucial are inside wall angles on the sealed side? Robertvon Enclosure Discussion & Design Construction Help 4 11-12-2013 06:31 AM
Cutting odd angles. davidrforbus General Car Audio Discussion & Questions 14 05-04-2012 01:58 PM
Battle Los Angles iamsonic Movie & Gaming Review 18 10-13-2011 10:43 AM
sick fight video from all angles Ryan1126 Off Topic Chat 32 03-18-2011 01:44 AM
Marking angles in sketch up? F3M4 Enclosure Discussion & Design Construction Help 0 01-31-2010 04:52 PM
