building inside of trunk - Car Audio Classifieds!
Old 08-09-2014, 09:05 PM
Default building inside of trunk
who on here has built enclosures inside of their trunks?
Is it going to suck as much as I think it will?
I've got 2 15's in the mail and plan on sealing off facing forward tuned to 25hz ported through deck. Problem is box won't fit through opening so I get to build inside.
I'm using .75" solid aspen and using L brackets to fasten the panels. I plan on using fiberglass to hold the enclosure together.
Old 08-09-2014, 09:11 PM
nkrell11's Avatar
0/11 sssss1420
Haha I'm about to build in the trunk of my grand prix single ZV4 18 firing forward I have a Kreg jig and all that bs it's going to be real interesting.
Jeep Build Log:
Daily (Rebuild Pending)
Old 08-09-2014, 09:24 PM
I have. It's not hard, but it can be really frustrating. You'll probably need an angle grinder and hammer at some point because of something stupid that's like 1/4" off. I used angle brackets and glass at the seams, but if I had to do it again I would kreg jig it. Try to build as much outside of the car as possible.
Old 08-09-2014, 09:40 PM
southcarolina803's Avatar
0/11 sssssss15
im doin the inside of an infiniti m35
Old 08-09-2014, 09:41 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
I put 2 15s in my trunk. kreg jig is an absolute life saver
Old 08-09-2014, 09:46 PM
I've only got to build a rectangular box since I'm using round ports. I'm mostly worried about the smell afterwards
Old 08-09-2014, 09:48 PM
goatskindreams's Avatar
Do you even demo?
0/11 sssss1797
just like jeff said, use a kreg jig Kreg Jig® Master System - YouTube
Team AST-2 15" Everest Sound Labs Bdx.Powered by Flatline audio ba2
Team Psychoacoustics-11" Adjustable Psycho Port. 12 T3 Audio 6x9s for mids
Old 08-09-2014, 09:59 PM
how will that be easier than using L brackets? I'm running 1krms not to worried about it breaking.
Old 08-09-2014, 11:19 PM
Authorized Vendor
0/11 ssss14115
cheaper since you wont need buy a bunch. stronger then a but joint and makes it very strong. you could use L brackets if you wanted but id personally use a ton of glue if you go that route
Old 08-10-2014, 02:45 PM
I won't be using any glue at all really.
I don't see how it will do anything after the inside is matted and glassed.
Building in the trunk and need some help jhg33k Enclosure Discussion & Design Construction Help 1 08-05-2013 06:39 PM
when building a box inside a car Lord Huggington General Car Audio Discussion & Questions 7 07-06-2012 08:17 PM
building a box inside the cabin of a trunk car. MERQUE General Car Audio Discussion & Questions 6 03-13-2012 11:05 AM
How to build a box INSIDE the trunk? westman995 Enclosure Discussion & Design Construction Help 12 06-24-2010 06:48 PM
