Help with box build with aeros - Car Audio Classifieds!
Old 08-12-2014, 07:41 PM
0/11 sssssss52
Default Help with box build with aeros
Im planning on building a box for a 15 AA Mayhem and im wanting to use some aero ports this time. I was thinking making the box 4.5cuft total with 3 4" precision port aeros the 17in long ones they have on parts express for 13$ each, there calculator says itll be tuned to 33hz and port displacement will be about .5cuft which would bring the box right around 4cuft. I dont wanna have to cut the aeros just buy and install. what do you guys think is this correct or am i missing something?
Old 08-12-2014, 08:36 PM
0/11 sssssss52
can anybody give me some advise on what to expect or anything im missing? it will be sub up and ports back firing off the hatch.
Old 08-12-2014, 08:44 PM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
Single 8" sono tube would work out better and is only $8 at Lowes... your current tuning would be 38hz before woofer displacement anyways for that volume. Doesn't seem big enough for an 15 to me either though..
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 08-12-2014, 08:47 PM
1loudmonte's Avatar
Team Incriminator Audio
0/11 sssss2167
Feedback Score: 36 reviews
If you end up with 4 cube net then 3 4" aeros 17" long would tune you at 36.6 hz and give you roughly 38 sq in of port aero. I would do like 2 6's or a single 8 if it were me.
(2015 MECA Street 3 World Champion)
2004 Dodge Ram Single Cab 1500
3 Incriminator Audio Judge 15s
3.25:1 Ratio 4th Order Blowthrough
1 x AA 9.0 TFHE, 2 x AA 150.4
4 X Crossfire XS-M8's, 2 x PRV Tweets
Old 08-12-2014, 08:58 PM
SPL Farms
0/11 sssss5706
Order of operations makes it 50" of port and around 38hz @4 cubes net from my calculations
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 08-12-2014, 08:59 PM
SPL Farms
0/11 sssss5706
Wait... I calculated for 4 4" aeros... not enough port area with 3 of them...
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 08-12-2014, 09:07 PM
0/11 sssssss52
so what can i do. i want to build this box for my 15 mayhem and i want it tuned somewhere around 33-34hz and itll be ran most likely with about 1500rms. Iv never built my own box so i dont know a whole lot and any advise would be appreciated
Old 08-12-2014, 09:08 PM
0/11 sssssss52
id be making the box to about 4.5 total and then the ports are .5cuft so it would bring it down to 4cuft
Old 08-12-2014, 09:14 PM
SPL Farms
0/11 sssss5706
I'd start at 5.5 and then run a single 8" aero about 22-24" long for about 5 cubes net and tuned 30-31
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 08-12-2014, 09:19 PM
0/11 sssssss52
where would i get an 8" aero 22" long? and how would i calculate the flare into all that?
Looking for box design for two sundown zv3 18"s using aeros Mnorwood01 Enclosure Discussion & Design Construction Help 1 05-11-2012 12:35 PM
Box with 1 18 and 4-4" aeros btsteinb Enclosure Discussion & Design Construction Help 5 03-15-2012 11:37 AM
# of 4" aeros for my box? mads10bass Enclosure Discussion & Design Construction Help 5 08-24-2010 07:42 PM
Blazer Box Build, 7.6cuft 30.5hz. (2 15'' PSI HCs, DSC Power, Aeros) *whoisasdf* AV8ter Build Logs 29 03-21-2010 10:39 PM
Building first box with aeros, can someone confirm length W O T Enclosure Discussion & Design Construction Help 15 09-29-2009 01:06 PM
