Help with aperiodic enclosure - Car Audio Classifieds!
Old 08-14-2014, 09:58 PM
0/11 ssssss245
Default Help with aperiodic enclosure
Does anyone here have experience with this type of enclosure? Trying to get some input on it before I waste alot of time and materials and then it doesn't work. First what I am building is mostly for wow factor but I still want it to sound decent. Yes I am prob crazy but thinking of 16 - 20 15" kicker CVR's (I have a new old stock, hook up) inside a quad cab dodge. Box will only have about 1 cu.ft. per sub and going to have the vent thru the floor open to outside. Been researching the size of the vent should equal to half of the displacement of the subs. I know its not the best box for low bass but plan on using an EQ to help out the lows. Again this is for the wow factor of so many subs, I know four ported would be better. I am thinking 6" in the kicks, 12's in the door maybe get really good SQ out of it. I will be running really low power, about 200 per sub.
Old 08-29-2014, 02:41 PM
0/11 ssssss245
Nobody? Any input?
Old 08-29-2014, 03:06 PM
98GMC's Avatar
0/11 sssss1265
Try DIYMA for Aperiodic.
Old 08-30-2014, 01:21 AM
Aperiodic (literally "not regular") in philosophy is similar to transmission lines in that the goal is to tame impedance peaks so that the speaker, at least from an electrical POV, does not appear to be in a traditional enclosure at all. As an example of what an ideal aperiodic enclosure should behave like, you can imagine a subwoofer with an extremely low natural resonance in a 1 cubic foot enclosure with a door on the back. As you play higher frequencies, the door is all the way shut, but decreasing in frequency the door opens more and more, so that any measurement of impedance would be riding somewhere on the tail of the resonance spike without ever reaching a peak. The attached picture demonstrates this, in that as you get lower in frequency and the fb peak is pushed lower and lower the impedance stays the same (green line). In reality this isn't possible because it relies on a speaker with no inherent physical properties. There are theoretically other forms of resonance shifting that would make for non-regular behavior; you could even make the same kind of setup but have the door open a random amount for every frequency. This would be aperiodic as well because the impedance graph would be all over the place.
Aside from the classical definition, when talking about real speakers with real mass, aperiodic works in a similar manner, with the ultimate result much like that of the adjustable door, but you still get the characteristic of a sealed enclosure. The goal is to get the characteristic impedance curve of a larger enclosure when the speaker is in a much smaller enclosure than would normally be necessary to get that response. You can do this with an acoustically resistive membrane, but the problem lies in the fact that most membranes have a tendency to act like the randomly opening door. If you just guess on the amount of stuffing you need, you end up with a peaky and wobbly impedance response that looks more like a really leaky sealed enclosure. So to get it sounding right takes a LOT of experimentation, and even then you can't guarantee that you'll ever get a response that sounds better than another type of regular alignment like a simple sealed or vented enclosure.
So since the end goal of going aperiodic is to make the enclosure seem larger than it really is, there's a much more simple answer: use a driver with a slightly lower QTC then you want to end up with and put it in an IB configuration. This shifts resonance down, increasing low end, and assuming the opening at the rear is large enough to not cause helmholtz effects, there's still a slight underdamping effect. None of this is to say you can't add some form of stuffing to the enclosure, in fact it's a good idea for (if nothing else) keeping outside noise from entering the enclosure and exciting the speaker cones.
I don't think stuffing a ton of 15"S in an IB config in a truck is necessarily a good idea, but it will work a hell of a lot better than trying to mess with aperiodic damping.
expo615 (08-31-2014)
Old 08-31-2014, 11:17 PM
0/11 ssssss245
So can you tune a sealed enclosure with an EQ instead of box volume? Build too small of an enclosure and lose low end efficiency and then just EQ the bottom end and overpower it?
So an aperiodic membrane enclosure is not making the subs sound like they are in a bigger enclosure, just the impedance curve of a bigger enclosure. You would still need an EQ to sound good.
Old 08-31-2014, 11:55 PM
0/11 sssss1411
Originally Posted by expo615 View Post
So can you tune a sealed enclosure with an EQ instead of box volume? Build too small of an enclosure and lose low end efficiency and then just EQ the bottom end and overpower it? - sort of yes but there are limits to how much power you can send to the sub before it is just not effective and or reaches mechanical / thermal limits also factor in the air spring effect on the small box - as the cone trys harder to move in and out at the lower frequencys its atempting to "stretch" the air inside the box for the desired amount of cone travel - so yes more power will attempt to move the cone more but too small of a box will still have limits on the cone travel.
- - if the impedance curve stays relatively flat - this means the amp will be sending more constant of a power curve in hz range to the sub.
when the impedance goes up - the power from the amp decreases to the sub
lets say you wired to 2 ohms resting load - and at 40hz the impedance curve spikes up to 4 ohms your amp will be pushing roughly half of its rated 2 ohm power at the 4 ohm load so the sub will be getting much less power during higher ohm values... i believe this is called "box rise" and its just something that happens... there are some ideas about keeping it from going wild but all in all its just something we live with and try not to worry about to much .
Aperiodic Mats - DIY? USD? Hertz5400LincolnLS Sound Quality Area 8 03-09-2013 07:19 PM
Aperiodic Enclosure Anybody build these? C3 Customs Enclosure Discussion & Design Construction Help 22 02-27-2009 04:58 PM
[COMPLEX] Aperiodic Membranes danteBirosel Tutorials & Quick References 0 11-12-2008 01:45 PM
