Would this port work? - Car Audio Classifieds!
Old 08-25-2014, 07:35 PM
0/11 sssssss70
Default Would this port work?
Whats up guys? I'm desining a new box to go in my hatch and was wondering if there would be any issues running my port this way and if the measurements for length would still be taken from the centerline showed in the pic. I didnt know if the 3/4" piece on the inside end of the box would be neglected since its such a small distance.
Old 08-25-2014, 07:41 PM
goatskindreams's Avatar
Do you even demo?
0/11 sssss1797
looks like a ton of port area.on the other hand i can't tell how tall the box is or how tall the port is. little more detail on the dimensions ?
Team AST-2 15" Everest Sound Labs Bdx.Powered by Flatline audio ba2
Team Psychoacoustics-11" Adjustable Psycho Port. 12 T3 Audio 6x9s for mids
Old 08-25-2014, 07:51 PM
0/11 sssssss70
Just the overall idea. The image is definitely not to scale. I was looking at the port being about 15.25"x4.5" and around 30" or so if i remember right. Im planning to go for something around 4.8 to 5cubes tuned to 32hz or a little less.
Old 08-25-2014, 07:52 PM
That is correct, although probably negligible. You should also include an end correction factor of approximately half the width of the port because the air mass won't stop abruptly at the termination inside the enclosure. One of the port walls is much longer than the other. As long as you're in the ballpark with tuning you're fine. Virtually every enclosure will change effective tuning slightly once put in a vehicle anyway due to coupling/loading with the environment around it. See picture.
File Type: jpg Screenshot_2014-08-25-16-57-55_zps9e76ce3f.jpg (20.8 KB, 12 views)
Old 08-25-2014, 08:15 PM
0/11 sssssss70
Great. Thanks for the info. So tune the length at the midpoint the way i have it and it should be close to my desired tuning?
Old 08-25-2014, 08:51 PM
Correct. If you don't account for that extra couple of inches of port correction, just know that you effective tuning will be a couple Hertz lower than you planned. You could also shorten the port a little bit to keep tuning up. Note that some enclosure design software will take into account the port end correction, so you wouldn't want to change it from whatever length it suggests (although like I said earlier, a couple inches here and there won't make much of a difference).
Would a 14" diameter aero port work in a 17.5 cube??? Mnorwood01 General Car Audio Discussion & Questions 3 11-22-2013 10:19 PM
which port would work better? Ryan1126 Enclosure Discussion & Design Construction Help 15 05-19-2013 08:42 PM
Will this port work well? joshua1davison Enclosure Discussion & Design Construction Help 2 03-19-2012 10:20 PM
Sub/port up in a trunk: does it work for daily? 1ndatrunk Enclosure Discussion & Design Construction Help 11 08-17-2010 10:04 AM
Will external slot port work good? westman995 Enclosure Discussion & Design Construction Help 2 04-12-2010 07:10 PM
