Box I designed for a HDC412. Will it work? - Car Audio Classifieds!
Old 08-26-2014, 03:12 PM
0/11 ssssssss9
Default Box I designed for a HDC412. Will it work?
This a box a designed for a SQ HDC412 and I wanted to know if it would work ok. Its going in 08 f150 supercrew and it will be ran on an AQ2200d
Old 08-26-2014, 03:42 PM
KickinBlazer's Avatar
0/11 sssss1122
Take a little bit of port area away get the square inches per foot around 15.5 or in the 15 range...16 square inch range will make it peaky and make it fall on its face any above tuning or below tuning
if its to loud your to old!
Old 08-26-2014, 04:04 PM
0/11 ssssssss9
would this be any better
Old 08-26-2014, 10:53 PM
0/11 sssss1122
Now that I read the specs for the hdc4 12 I would have it in 2 cube net and 15 square inches of port per cube....2.125 net max
Old 08-27-2014, 02:43 AM
0/11 sssss5305
What are your goals for this set up? I'm assuming you'll be running the amp at .5
Old 08-27-2014, 05:05 AM
0/11 ssssssss9
Why only 2cubes? Yes it will be ran at .5ohm and i do have the electrical for it. I just wanr ro make it as loud as i can
Old 08-27-2014, 01:42 PM
0/11 sssss1122
more cone control in high power aplications with smaller boxes so being that your going to be throwing 2.5krms to the sub i would get it around 2.1 or 2.2 cube net your wanting to just get loud and not be able to play much music? id tune right at 40hz.....but you want to play some music tune around 37hz....more musical tune around 33hz
Old 08-27-2014, 03:28 PM
0/11 ssssssss9
well I want it to play lows to. The box its in now is tuned at 36 and it gets low just now low enough where I want it. Im not go for spl or anything just loud as it possibly can get on music
Old 08-27-2014, 03:45 PM
0/11 sssss1122
OK leave it at 33hz tune 2.1 to 2.2 cube and 15 square inches of port per cube and there ya go
Need a box designed for 2 FI Sp4 15s Optimus_Prime Enclosure Discussion & Design Construction Help 0 04-10-2013 12:10 AM
Need a box designed, $$ involved of course. nicyousuckk General Car Audio Discussion & Questions 5 09-19-2011 12:53 AM
I need a crazy box designed for me littleharv93 Enclosure Discussion & Design Construction Help 2 07-18-2011 02:11 AM
most PITA box I have ever designed korey_hofer Enclosure Discussion & Design Construction Help 18 12-15-2009 08:56 PM
Check this DD designed box design? da box king Enclosure Discussion & Design Construction Help 8 08-16-2009 07:54 PM
