ATTN Eclipse Drivers and Box Designers - Car Audio Classifieds!
Old 09-09-2009, 09:16 PM
aturcotte127317's Avatar
Veteran Member
0/11 sssss3613
Default ATTN Eclipse Drivers and Box Designers
Ok so i am getting soem new subs in for the eclipse, going with two WMD2 10s. Anyways the specs on these particular WMD2s are a bit different then the standard ones because of the triple spider vs. the standard one spider. They are as follows
9.375" cutout
WMD210-.196 cft
revc 2.1 ohms
fs 38 hz
qes .5
qms 5.5
qts .45
le 1.1
vas .49 ft^3
sens 83.8 @ 1w1m
If you compare these with the standard specs you see the VAS is a lot lower, (these love small boxes) and the FS a lot higher.
Bottom line is, i am trying to keep the enclosure within:
32wx15hx13d (That is if i am going to do subs and port back)
or
32wx13hx15d (If i am goign with subs up port back)
Now i am thinking about doing two boxes, one for daily and one for SPL.
Also looking for someone with exp. who knows whether CRX boes work best in eclipses or if sub and port back work better
147.5 sealed on dash
149.0 in kick
and climbing
2 12" 2010 Type Rs
or
1 15" DD 9915
Audison VRX 1.500
or
Sundown SAZ1500D
Crescendo 1000C4
SHOK wire
Old 09-09-2009, 09:46 PM
Veteran Member
0/11 sssss3613
here are a few i came across:
2cubes after disp @35Hz
2cubes after disp @36Hz
2 cubes at 32 Hz (for daily)
149.0 in kick
and climbing
2 12" 2010 Type Rs
or
1 15" DD 9915
Audison VRX 1.500
or
Sundown SAZ1500D
Crescendo 1000C4
SHOK wire
Old 09-10-2009, 09:09 PM
Veteran Member
0/11 sssss3613
any help please??
149.0 in kick
and climbing
2 12" 2010 Type Rs
or
1 15" DD 9915
Audison VRX 1.500
or
Sundown SAZ1500D
Crescendo 1000C4
SHOK wire
ATTN: Pat, Madmat, Spy..... others? RollerDJ Technology & Computer 24 09-01-2009 10:38 PM
ATTN: Mytyeerinpie 92K1500 Off Topic Chat 13 07-29-2009 04:19 PM
Attn. 3G Eclipse Drivers aturcotte127317 General Automotive Chat 12 05-11-2009 04:33 PM
ATTN: Dantebirosel RollerDJ Off Topic Chat 32 11-13-2008 11:33 AM
