Tips/Tricks to accessing subs in 6th order?? - Car Audio Classifieds!
Old 08-31-2014, 08:54 PM
oxsign's Avatar
0/11 sssss1876
Default Tips/Tricks to accessing subs in 6th order??
I'm about done with my 6th order, and I was wondering if there is a way to seal the top properly but still be able to get to the subs if one blows or something happens??
1971 VW Fastback
Old 08-31-2014, 08:55 PM
mega fatty
0/11 sssss6008
Make it big enough so you can climb inside it
Old 08-31-2014, 08:58 PM
0/11 sssss1411
ive seen people use foam weatherstriping tape avalable from home depo. then just screw the lid down good.
you need to be able to axess your subs to check from time to time that the screws holding them on are tight - and or not broken off. ive had a few screws break off before and was hard to diagnose the strange rattle sound...
The Following User Says Thank You to brian84corvette For This Useful Post:
oxsign (08-31-2014)
Tips/Tricks on building a 4th rdlyn13000 General Car Audio Discussion & Questions 17 08-26-2014 09:10 AM
Sanding Tips & Tricks rdlyn13000 General Car Audio Discussion & Questions 10 04-25-2014 10:35 AM
4th or 6th Order? Question/Help/Advice/Tips/etc Please David97 Enclosure Discussion & Design Construction Help 7 11-04-2011 11:58 AM
Help With SPL Tips and Tricks coddehart General Car Audio Discussion & Questions 22 09-02-2010 04:53 PM
Box tips and tricks... RetroAudioInc Enclosure Discussion & Design Construction Help 5 12-10-2009 09:44 PM
