2 sundown x10s - Car Audio Classifieds!
Old 09-07-2014, 09:36 PM
Silver03gt's Avatar
0/11 ssssss687
Default 2 sundown x10s
Is is possible to run 2 sundown x10s in this box? If possible, I am not too sure if I did the port right and I dont know how to calculate in the bracing. If you could help me with that stuff and tell me what I need to do with the design that would be greatly appreciated. Also, I could build the box in sketchup if that would help.
2017 Chevrolet Silverado LT 1500 - Mechman 320 amp alt, possibly 4 DC M3 8s center console, some 3k amp.
2005 Ford F150 - bagged on 24s. Maybe new sound vehicle. (SOLD)
Old 09-07-2014, 09:38 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
pic is tiny... calc bracing (area) and add it to the miscellaneous category or whatever one is displacements
Old 09-07-2014, 09:43 PM
Silver03gt's Avatar
0/11 ssssss687
So if I was using bracing as 1 dowel rod at 1/2", I would just calculate as .50?
Old 09-07-2014, 09:46 PM
Silver03gt's Avatar
0/11 ssssss687
Lets try this one.
Old 09-07-2014, 09:54 PM
NEVERDONE's Avatar
0/11 sssss2471
Port area looks to small. I would try for more. I did a box for one that had 14 per and it got down..
Old 09-07-2014, 09:57 PM
Authorized Vendor
0/11 ssss14115
what is the diameter of the dowel and how long is it?
do volume of a cylinder and make sure its in sq foot then add that to the " bracing" section on torres... net size is fine since bracing isn't added yet too... tuning is fine.. port areas a little shy though for my test per slotted
Old 09-07-2014, 09:58 PM
0/11 ssssss137
yeah make the port 4~6 inches wide.
Old 09-07-2014, 10:00 PM
Silver03gt's Avatar
0/11 ssssss687
What should I change to get my port area higher? If I change the length I can get around 12 sq in of port but the port would be 50 inches long and tuning is 24 hz. I change width to 5 and get 35hz. Am I doing the port right or should I switch the numbers for width and height around?
Old 09-07-2014, 10:04 PM
Silver03gt's Avatar
0/11 ssssss687
Here is another quick edit. I am garbage at this.
Old 09-07-2014, 10:05 PM
Silver03gt's Avatar
0/11 ssssss687
I dont have it yet so im not sure. What would your recomment for double baffle with 2 x10s?
wtb 2 sundown x10s and saz2500 Throwback559 Wanting to Buy (WTB) 6 04-09-2014 01:56 PM
WTT:Brand New Sundown SA D2 15 for 2 Sundown E 15s or 800+ rms Mono Amp dstack2 Car Audio Trader (WTT) 11 12-24-2012 12:52 PM
Another National Record for Team Sundown Russia - 156.2 - Sundown z15v2 Skillz (Sundown Audio) 13 01-23-2012 08:33 PM
Team Sundown Russia-Rostov aka Sundown Mafia Skillz (Sundown Audio) 10 06-27-2011 11:36 AM
6 Sundown SA12s and 1 Sundown 3500.....FLEXXNG fuse POP Skip01 Car Audio Videos 19 06-23-2011 08:21 PM
