sub mounting location - Car Audio Classifieds!
Old 09-07-2014, 09:40 PM
Highs On Bass's Avatar
I'm F*CKIN Sexy!
0/11 sssss2132
Default sub mounting location
so i'm looking to build a new box, and i'm curious, if say i'm running 4 12's, and 2 12's are mounted on the top of the box and 2 on the sides... will it work? or am i going to face some serious cancellation?
Yep... I'm an AMI NUT HUGGER>.. HE's the master of my wood
Current scores to date as of 12/5/2010:
Sealed 152.9
Outlaw 156.6
Old 09-07-2014, 10:06 PM
I'm F*CKIN Sexy!
0/11 sssss2132
and basically i'd have 2 on the top of the box and two on the face side, its going in an ext cab truck, so to subs firing up, and two firing at the back of the seats...
Sealed 152.9
Outlaw 156.6
Old 09-07-2014, 10:08 PM
Silver03gt's Avatar
0/11 ssssss687
My buddy did this with his car and he had so cancellation and loading issues. Since it is an extended cab truck, is it possible for you to put the on the top side to side?
2017 Chevrolet Silverado LT 1500 - Mechman 320 amp alt, possibly 4 DC M3 8s center console, some 3k amp.
2005 Ford F150 - bagged on 24s. Maybe new sound vehicle. (SOLD)
Old 09-07-2014, 10:15 PM
I'm F*CKIN Sexy!
0/11 sssss2132
i guess i could do all subs across the top and port out the side....
didn't really think of that, but then again, the port will have about 3 inches blocked off because of the way the c pillars come down on the the truck...
Sealed 152.9
Outlaw 156.6
Old 09-07-2014, 10:22 PM
Yes it will work, no you won't get cancellation. The general rule is that as long as the speakers are spaced within 1/2 wavelength you will get some form of constructive interference, the closer the better (at 1/2 wavelength the positive cycle of one speaker is being cancelled by the negative cycle of the other speaker). As an example, at 80hz the wavelength is about 14ft, so you would want to keep path-length difference between you and each sub less than 7 feet. As you get lower in frequencies the allowable PLD becomes larger because the wavelengths are longer, so it's fair to say that it's going to be really difficult to get true wave cancellation at bass frequencies in a car.
There will definitely be an effect on the overall modal response though. I doubt it will be detrimental.
edit: I didn't read that this was going in a truck; I though this was in a car trunk. If that's the case then you might have issues. Truck cabs are almost like tiny cubes and tend to get weird modal issues.
Old 09-07-2014, 11:03 PM
I'm F*CKIN Sexy!
0/11 sssss2132
i guess i'll just stick with 2 15's in place of 4 12's. otherwise i'd have to run areo's and do sub forward port up...
Sealed 152.9
Outlaw 156.6
Old 09-07-2014, 11:14 PM
I'm F*CKIN Sexy!
0/11 sssss2132
Sealed 152.9
Outlaw 156.6
New Location mrogowski General Car Audio Discussion & Questions 6 04-05-2010 09:25 PM
Midrange mounting location: 2 Options Only NoMids General Car Audio Discussion & Questions 10 09-30-2009 12:36 PM
mounting location RidnClean General Car Audio Discussion & Questions 73 12-03-2008 08:34 PM
location sholiz Announcements - Suggestions - Feedback - Support 6 08-25-2008 06:47 AM
