First wall build for 4 obsidian audio 15s - Car Audio Classifieds!
Old 09-23-2014, 09:28 PM
Kcbme's Avatar
0/11 ssssss526
Default First wall build for 4 obsidian audio 15s
How does this look for 4 obsidian audio 15s? I listen to decaf and slowed music 85-90% of the time and normal radio music the rest.
in case picture is to small here is run down on the wall.
38height,40width,28depth
port is 36.5h,6w,20d
14.96^3 with 14.64 sq inches of port per foot and tuned to 33.5 hz
Feel free to critique or help me out.
2001 suburban
2.8:1 4th
4 db drive wdx 7k 18s on 2 crossfire 8ks
Old 09-23-2014, 09:36 PM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
Are they the v3's?
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 09-23-2014, 09:59 PM
Kcbme's Avatar
0/11 ssssss526
no v2's
2001 suburban
2.8:1 4th
Old 09-23-2014, 10:08 PM
SPL Farms
0/11 sssss5706
Hmmm... I believe we put 2 v3 12's in 4 cubes @32 hz with an 8" aero on a saz 2500 in the wrx. Very impressed with the sound and power handling. Wired at 1 and rising up so probably close to rated RMS and it did 145 on the glass. I believe you are probably pretty close but can't say for sure as I haven't had any experience with v2's.
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 09-23-2014, 10:51 PM
Kcbme's Avatar
0/11 ssssss526
the v2 and v3 is not too different from what I heard but I could be wrong. Amp is going to be an AB 150.1 for now wired at 1 ohm so 3k b4 rise. This is if I can get another v2 15, if not plans may have 2 change for 2 18s.
Any idea what size areo port I would need for 4 15s? Never used an aero before.
2001 suburban
2.8:1 4th
Old 09-23-2014, 11:54 PM
SPL Farms
0/11 sssss5706
Depends on volume. My enclosure is just over 12 net and I'm using 2 8" aeros. The new enclosure I'm about to build for the new project is going to be about 11 net with 2 8" aeros as well
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 09-24-2014, 12:15 AM
Kcbme's Avatar
0/11 ssssss526
its 14.96^3 net,I still haven't heard back from nick at OA if he even has a motor to rebuild me another v2 and idk if I am gonna try find a used one so I may just sell all 3 i have and buy 2 ethos 18s, but whats the general rule of thumb with aero port,like 12 sq in per foot?
2001 suburban
2.8:1 4th
Old 09-24-2014, 01:57 AM
massivespl's Avatar
0/11 sssss8409
If your using areos go 9" per cube... 4 6" aeros for 4 15s
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
4 Obsidian 15s wall on DD m3 kr-15 Car Audio Videos 5 03-31-2013 03:36 PM
4 Obsidian 15s wall kr-15 Enclosure Discussion & Design Construction Help 0 03-01-2013 08:33 PM
wall or no wall, scion xb, Obsidian audio 18's 98Expo Enclosure Discussion & Design Construction Help 20 06-07-2012 10:48 AM
2 obsidian 15s build 2000LaDe General Car Audio Discussion & Questions 27 10-29-2011 08:47 PM
Trailblazer 4 15" Obsidian Wall Build bumpin buick Build Logs 33 05-13-2011 08:39 AM
