Removable sub enclosures...who's built them? - Car Audio Classifieds!
Old 10-08-2014, 11:58 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Default Removable sub enclosures...who's built them?
As title states looking for ideas too see who has done this. And provide pics as well. For instance...if your box bolts down how would you remove it w/o undoing the sub's? I got an idea in mind but wanna see some ideas.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 10-09-2014, 01:08 AM
doug118's Avatar
0/11 sssss4674
Could always use vertical threaded rod that protrudes through the top of the box, but goes through the box and into the floor? Is that what you're talking about? Hidden security features?
Old 10-09-2014, 02:39 AM
0/11 ssss12531
Sure. Whatever it is, tie down strap Velcro bolted etc.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 10-09-2014, 09:26 AM
BigBen's Avatar
0/11 sssss3006
Feedback Score: 24 reviews
I'm gonna velcro my next box!!
Old 10-09-2014, 10:01 AM
doug118's Avatar
0/11 sssss4674
Nevermind. I was thinking of this thread as an anti theft ideas thread. Why would you secure a box if you want it to be easily removable?
Old 10-09-2014, 10:52 AM
xnewbx's Avatar
0/11 ssssss985
What do you mean, without undoing the subs? Every box is removable unless you fiberglassed it to the car.
Old 10-09-2014, 11:45 AM
0/11 ssssss416
I've used l brackets several times to hold sub boxes down. Seems to work just fine. Usually carpet them or paint them depending on what would look better in each case.
Old 10-09-2014, 11:59 AM
aqlover's Avatar
0/11 ssssss737
I have used L brackets and velcro in the past
What is this ES-PEE-EL you speak of?
Old 10-09-2014, 01:51 PM
socalxj's Avatar
0/11 sssss2371
I have built many removable enclosures. Two reasons #1 I have owned 5 cherokees all built for wheel'n, #2 bolts and L brackets transmit mean resonance to body which colors the sound. I use tabs on bottom of enclosures meaning the bottom is about 3 inches per end longer then I fasten using well nuts and rubber washers to absorb resonance and close cell foam the bottom of enclosure that meet the body.
Buy Well Nuts At Fasteners plus | Blind Nut
Yoga Mats, Exercise Mat, Polyethylene Foam, Yoga Mat, Exercise Mats
Old 10-09-2014, 02:58 PM
0/11 ssssss542
12 cans of great stuff. removable with an ice pick, tow strap, and chevy avalanche.
custom built sub enclosures for cheap marcotheclepto Speaker Accessories & Parts 53 01-23-2013 06:38 AM
Custom Sub Enclosures designed and built by SPY SPY Off Topic Chat 52 05-30-2011 10:44 PM
Hand Built Enclosures Proof............ Ami Creations General Car Audio Discussion & Questions 49 07-16-2010 10:15 PM
