4th order SA-10's - Car Audio Classifieds!
Old 10-22-2014, 10:19 AM
Silver-N-black's Avatar
0/11 sssss3544
Default 4th order SA-10's
Hey guys wanted to see if you guys can help me out. I really like the sounds of 4th orders and want to build one for my daily. Not a box designer so take it easy on me, max dem i have are 32WX16-18DX14H. Box is going into a GS300, using the stock 8" sub location for the port.
Let me know what you guys think of the box size and if it would work? Have no clue about the port or port size.
Going to be using a PPi 1800.1
The Following User Says Thank You to Silver-N-black For This Useful Post:
sthrnbumpn (10-22-2014)
Old 10-22-2014, 11:00 AM
0/11 sssss4519
I did a similar build with two XFL10s through the ski hole. Turned out very good and plays great. .4 sealed per sub and the rest ported. Tune it about 55hz and shrink the port as you desire.
To find sealed resonance
resolve Vas/28.32 =
result of that +1
square root that result
Old 10-22-2014, 03:50 PM
0/11 sssss3544
Yeah i think this will turn out great just need some help with them port an maybe the rest of the box.
Old 10-22-2014, 03:52 PM
0/11 sssss4519
I'll do the design for you if you want but it'll have to wait till Friday night.
resolve Vas/28.32 =
result of that +1
Old 10-22-2014, 04:16 PM
0/11 sssss3544
PM and lets talk..
Old 10-22-2014, 05:41 PM
Do just like you have in that picture, but place the baffle 3.5" to 4" away from the back wall. That should give you about 0.8 ft^3 of airspace for both subs and give you a sealed resonance around 48-50hz. Use a 6" round port 8"-9" in length, preferably with a few inches external through the rear opening so it doesn't get too close to the bottom of the enclosure on the inside terminus.
Old 10-23-2014, 11:37 AM
0/11 sssss3544
I should have around 4-5" from the box to the top of the rear deck. So your saying 4" to give me 0.8FT^3. Share airspace on the sealed side or not?
Old 11-04-2014, 07:10 PM
0/11 sssss3544
2 SA-10 will be here on Friday. Might get started with the box over the weekend.
8 XD 10's In A Crazy 4th Order! got160s? Car Audio Videos 4 09-28-2012 01:49 PM
16 SA-10's 4th order Scapelli21 Build Logs 125 09-18-2012 10:48 AM
Z or Nightshade 10's in a 4th order?? Oldbass38 (Sundown Audio) 7 06-28-2011 08:29 AM
4 10's in a 4th order project. ltr450racer690 (Sundown Audio) 54 02-25-2011 11:39 AM
4th order box for 3 10's cubnb79 Wiring, Electrical & Other Installation Equipment 12 11-30-2010 01:41 PM
