Sa12 sealed or 2 e8v3's ported box help - Car Audio Classifieds!
Old 10-22-2014, 10:45 PM
0/11 sssssss20
Default Sa12 sealed or 2 e8v3's ported box help
I have a 2011 ram crew cab and currently have an sa 12 in a sealed box under the rear seats, box is around 1.25 cubes on 500 watts. It starts to drop off quickly below 36 hz, so I am looking to change it up. I am considering rebuilding the box to get as much airspace as I can and run the sa sealed, or run 2 e8v3's ported. Does anybody know how to tune the port in a fiberglass box? Which setup is going to play lower than what I currently have? I'm not looking for tons of spl, as the system is geared more toward sq but all types of music are lacking in the lower frequencies right now
Old 10-22-2014, 11:28 PM
Is there any way you can add an external port to the sealed enclosure you have now? If you can cut a hole in the box and extend a 4" diameter piece of PVC that's 22" long you'll gain well over 6dB from 30-50hz. That gives you a 33hz tuning. You can go lower with a longer port.
Old 10-23-2014, 10:12 AM
0/11 sssssss20
Adding a port to this box is going to be difficult. The only flat part on the box is the baffle which is around 3 inches from the bottom of the seat so not a lot of room. Would a 3 inch round port be enough port area for an sa12? I'm pretty sure I could fit a 3" port inside the box if I re-baffled it and added a few layers to make it taller. Would love to run this sub ported in this truck.
Old 10-23-2014, 10:44 AM
I did a quick sim in BBP6. On 500w with a 4" port you're peaking at 28m/s vent velocity at around 30hz. Dropping to a 3" port of the same tuning takes that up to 48m/s at 30hz, and that's waaaay too much. It will work, but I'd expect noticeable chuffing around 30-40hz. You could do two 3" ports, both about 26" in length if you have the room. If you have enough area on the baffle you could use two 90 degree elbows to sink into the baffle and run the ports "sideways" under the seats. I have no idea if you have room for this though, lol.
Old 10-23-2014, 09:21 PM
0/11 sssssss20
Here's a couple pics of the box. Not a lot of room under the seat. I am thinking I'm going to extend the box over into the other cubby. I am also going to add 2 layers to the frame the baffle mounts to for more depth. I might be able to squeeze a 4" port in the box, just need to find a 90 degree coupler that bends sharp enough so the port exits on the baffle.
Old 10-23-2014, 09:22 PM
0/11 sssssss20
Another pic
2 12s ported, 2 15s sealed or 1 15 ported? macandcheese General Car Audio Discussion & Questions 25 01-19-2013 08:19 PM
EC Truck - Small Box, 1000 Watts - Ported 8" or 2 sealed 10's? rlj676 General Car Audio Discussion & Questions 0 11-10-2011 05:51 PM
FS: ported and sealed box Ryeguy28 Miscellaneous Stuff For Sale 1 04-10-2011 08:54 PM
Small Ported box or Sealed box Beatdown337 Enclosure Discussion & Design Construction Help 9 05-27-2010 03:17 PM
How to calculate weird box size?? Stay sealed or go ported? westman995 General Car Audio Discussion & Questions 8 08-13-2009 12:41 AM
