Enough port area per foot? - Car Audio Classifieds!
Old 11-01-2014, 01:08 PM
davidrforbus's Avatar
0/11 sssss6030
Feedback Score: 59 reviews
Default Enough port area per foot?
Ive got 13.5sqin port per foot for 2 obsidian 15s, will that work or is something around 15sqin gonna be what I need?
Old 11-01-2014, 01:11 PM
0/11 sssss1882
Nice to see you back around.
Are you doing aero or slot? Either way, should be fine. That is a tad over for aero and a tad under for slot for most rule of thumb ive seen.
You should be good to go.
Old 11-01-2014, 01:13 PM
0/11 sssss6030
I know man. Works been keeping me busy just now getting back to working on the build. Its a slot port.
Old 11-01-2014, 01:16 PM
0/11 sssss1882
Whatre you tuned to? Whats your box layout?
Old 11-01-2014, 01:19 PM
0/11 sssss6030
Tunings is around 32 port drivers side. Box is 48x19x22 double baffle. Subs and port up in the cab of my ranger.
Old 11-01-2014, 01:24 PM
0/11 sssss1882
Sounds like it'll get down pretty good man. How much space you got between your port/roof?
Old 11-01-2014, 01:27 PM
0/11 sssss6030
A ton, Well over 25"
Old 11-01-2014, 01:33 PM
0/11 sssss1882
Yeah. You're fine imo. Maybe some of the lurkers can chime in to confirm?
I'm only speaking from research/reading btw. Only built a few boxes myself.
The Following User Says Thank You to southernbass For This Useful Post:
davidrforbus (11-01-2014)
Old 11-01-2014, 01:37 PM
0/11 sssss6030
Gotcha man. I think it'll be fine too but just wanted to be sure. Not wanting to cut another port.
Old 11-01-2014, 02:44 PM
0/11 sssss1085
Feedback Score: 23 reviews
Port area is relative to power, as in a port sized for 200 watts will be much smaller than one sized for 2000 watts. How much power do you have?
port area alacran Enclosure Discussion & Design Construction Help 12 04-25-2014 01:05 PM
help with port box a per and port area per ft lilsoccersully Enclosure Discussion & Design Construction Help 0 05-02-2012 09:04 PM
Port area vs. Port length TaylorFade General Car Audio Discussion & Questions 3 10-20-2011 09:52 PM
How much port area? DeadlySones Enclosure Discussion & Design Construction Help 15 07-22-2009 11:45 AM
