Port length for Sundown X18 - Car Audio Classifieds!
Old 11-04-2014, 09:54 AM
0/11 sssssss29
Default Port length for Sundown X18
I'm getting ready to build a box for a Sundown X18. I have an internal volume of 8 cubic feet. I'm going to do a rectangle port 3" wide and 17 3/4" tall. I need to know what depth to make it for it to be tuned to 32hz. Thanks in advance.
Old 11-04-2014, 10:02 AM
redcon1's Avatar
Broke & Horny
0/11 ssssss526
You might want to make the port a little bigger.
Old 11-04-2014, 10:43 AM
0/11 sssssss29
I could go 4" wide
Old 11-04-2014, 10:45 AM
Assuming you've accounted for the displacement of the port and 8 ft^3 is your net volume, the port needs to be about 13" long. It will vary an inch or two depending on it it's a slot port or not, but anywhere between 12-14" will be close enough as to not change tuning noticeably. If 8 ft^3 is the net volume before any displacement from the port, add about an inch to the port length
If you added another inch to the width (making it 17.75"x4"), you'd need to have a port length of about 17" for the same tuning. IMO it's worth getting that extra few square inches of port area by increasing the port length a bit. The swept volume of the x18 is huge and will excite the port pretty violently at higher levels, so you want as much port volume as you have room for. Redcon has a good point. Going to a 4" width will drop peak vent air velocity by over 30 ft/sec at just shy of xmax and you shouldn't' get any port compression or noise with that size.
Old 11-04-2014, 11:04 AM
0/11 sssssss29
Thank you. With the 8 cubic feet I took into account for the port, sub, and braces. 4" wide it is. Thanks again
Physical port vs port length? Twitney181 Enclosure Discussion & Design Construction Help 7 03-29-2013 11:38 PM
Port Length vs. Physical Port Length nicholask1993 Enclosure Discussion & Design Construction Help 28 10-21-2011 03:01 PM
Port area vs. Port length TaylorFade General Car Audio Discussion & Questions 3 10-20-2011 09:52 PM
Port Length? realrich159 Enclosure Discussion & Design Construction Help 9 05-20-2011 01:53 AM
