HDS3 10" Port Area - Car Audio Classifieds!
Old 11-05-2014, 10:25 PM
0/11 ssssssss9
Default HDS3 10" Port Area
Is 37.5in^3 enough port area for 2 Soundqubed HDS3 10"s in a 3.57in^3 box? 10.5in^2 per foot. Box is big for the subs so I don't know how relevant in^2/foot number is.
Old 11-06-2014, 06:08 AM
What's your tuning frequency? How much power? Just eyeballing it you're probably fine, but there's no way to know until you model it. Answer those for me and I'll see what I get.
The general rule-of-thumb port area/cubic foot suggestions are there because it's kind of a safe range for people who either don't know how or refuse to model it up. Vent air velocity will depend on power, tuning frequency, enclosure size, and the swept volume of the subwoofer(s).
Lucas_Walker (11-06-2014)
Old 11-06-2014, 10:55 AM
0/11 ssssssss9
31.5Hz and ~2400 watts. I've modeled it in WinISD and the port air velocity peaks at like 30m/s. I used a JL 10W7s as the drivers.
Old 11-06-2014, 11:56 AM
I'm getting about the same - around 33m/s at 30hz. Thirty m/s is typically considered the max you want to have, and it would be nice to bring it down a bit, but I don't think you'll have any issues on music even at really loud volumes. See the attached picture for my results.
Old 01-01-2015, 03:20 PM
The_Dealer's Avatar
0/11 ssssss212
This is just me, but I like to try to keep it around 24-26 m/s. My first ported box I built was showing 28.xx m/s in WinISD, but had just a tad bit of noise around 55hz. You couldn't hear it unless you were right by the box. I rounded the port entrance, and pulled the sub to round the other end the best I could. It fixed the noise issue until I bought a bigger amp. Ever since then I've tried to keep it in the lower mid to 20's. I'd try to make the port a little wider if possible, I think adding 1/8-1/4" more width to the port would drop you in a good range. Shouldn't add too much more length to get to your tuning. If you can afford losing a little, I'd definitely try to squeeze a little more. Hell I'm running 31.5 in^2(18.2 in^2 per cube) for 2 XD8's and half the power you're running. That's just my 2 cents, I'm still learning so I could be wrong.
Sent from my Samsung Galaxy Tab®4 on 38's
Old 01-16-2015, 05:46 PM
0/11 ssssssss9
I ending up building the box with 47.5in^2 of port area and I like it.
Old 05-28-2015, 11:20 PM
The_Dealer's Avatar
0/11 ssssss212
How did you get more+bigger graphs in bbp6? I can't seem to figure it out.
Single AB XD 8" port area The_Dealer Enclosure Discussion & Design Construction Help 1 05-22-2014 12:13 PM
Clarify "cone area" & pick my port! stssilverado General Car Audio Discussion & Questions 2 11-20-2013 07:15 AM
Can anybody tell me the port area of a 12", 14", 16", areo port ????? Mnorwood01 General Car Audio Discussion & Questions 19 11-15-2013 05:48 PM
port area for two 15" level3 scfaust (DC) 1 08-12-2011 10:02 PM
how much port area for two 12" subwoofers michigancapri92 General Car Audio Discussion & Questions 4 07-20-2011 07:21 AM
