Reccomended port area for a SA 15 - Car Audio Classifieds!
Old 11-07-2014, 04:52 PM
0/11 ssssssss7
Default Reccomended port area for a SA 15
Right people I've been playing with a few different subs in my Jetta and now have a sa 15. I'm currently running a temp setup 3.5cuft sub forward port forward with a 6x6 port giving me 36"^ port area. It sounds ok but I'm pretty sure I can get much better as the old school Rockford he15 I was running before hit harder on certain tunes.
I've been troving the net and found an article saying the perfect port to vol ratio is 16sq.ins per cuft which would make a port are of 56"^ can someone help me out here thank in advance!
Old 11-07-2014, 05:00 PM
Team Soundworks
0/11 ssssss203
I generally have good results using 16 sq in per Cubic foot.
2001 NSPL World Champion (4 Petras Hyper Throw 15's on 4 Earthquake 50UHC's) 153.1 DB No wall.
Current Setup: 1997 Astro (10 Skar Audio 15's, Still in da works
Old 11-07-2014, 05:16 PM
0/11 ssssssss7
I've read the ultimate configuration is port area equalling sub area it kinda makes sense as the port air mimmicks the driver movement what's your views on placement in a sedan I'm on the 3rd box modification now and not feeling like I'm getting anywhere!
Old 11-07-2014, 05:39 PM
Todd Dupler's Avatar
Team SPL Farms
0/11 sssss5000
For best musical results in my jetta i did subs up ported to the driver side. Where are you tuned currently and where were u trying to be tuned?
01 Volkswagen Golf 2 door
Kenwood ddx470
Old 11-07-2014, 06:11 PM
0/11 ssssssss7
I'm currently tuned to around 35hz which I've read is the golden frequency for the sa 15. My temporary port is only 36 sq in which is a little small for the 3.5 vol but I'm not getting the dangerous movement I was getting on certain frequencies when I had a smaller port. When you say sub up port drivers side do you mean sub firing up towards the lower rear window line and port facing the drivers side rear wheel well? Sorry if I'm sounding stupid but it's hard visualising without pictures!
Old 11-07-2014, 08:03 PM
Team SPL Farms
0/11 sssss5000
Its cool. I mean sub up and port firing into rear driver quarter panel. There is a album in my profile of one i did in my jetta
Kenwood ddx470
help with port box a per and port area per ft lilsoccersully Enclosure Discussion & Design Construction Help 0 05-02-2012 09:04 PM
Port area vs. Port length TaylorFade General Car Audio Discussion & Questions 3 10-20-2011 09:52 PM
ported box smaller than reccomended jrgreene1968 Enclosure Discussion & Design Construction Help 7 07-31-2011 03:05 PM
port area agog86 General Car Audio Discussion & Questions 26 02-18-2011 07:02 PM
