single layer shells? - Car Audio Classifieds!
Old 11-08-2014, 06:59 PM
Nate Futuristic's Avatar
0/11 ssssss768
Feedback Score: 21 reviews
Default single layer shells?
Ok so mdf is like 33 bucks for 3/4
Baltic birchis 65+ special order
That cheap birch ply is 45 a sheet
My question is is using 2x4s pl and screwed to a single layer enough (entire outer shell) and then maybe like some cross sections added enough?
Ive always double (current wall is triple layered)
But spending 33 dollars a sheet 14 sheets is just nuts lol
Ive seen metal shells working with single layer outer shells
But at 2.75 thick and some internal bracing im thinking ill be fine?
Baffle will de double layer with bracing internally for sealed section
And yes it is cheaper i can get 8 foot long 2x4s for like 98 cents
Plus 230 for 7 sheets vs
460ish for 14 sheets
Old 11-08-2014, 07:31 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
2x4s in a frame fashion (2x2 side attached to the wood) 6" on center would be oober strong
Old 11-08-2014, 07:41 PM
0/11 ssssss768
Haha yeah that would be alot of 2x4s thoim figuring 35 id have to double that lol
Box will be 72 long 33 high 42 wide without 2x4s
Im leaving about 2.5 inches off top and bottom and sides will have a good 4 inches due to the topper
Old 11-08-2014, 07:48 PM
Authorized Vendor
0/11 ssss14115
you can save wood and run them angled. itlls be stronger that way as well since the whole sheet would have to bow out
Nate Futuristic (11-08-2014)
Old 11-08-2014, 07:56 PM
0/11 ssssss768
Yeah i was just gonna do length ways haha
Diagonal sounds betterand ill see if i can fit a few going the other direction
Old 11-08-2014, 09:03 PM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
IMO.. the real deal birch is worth it. I used it on my most recent box. Double all the way around and triple baffle with no bracing so far and it's already extremely strong.
Current Build:
#60sHereIcome
Old 11-08-2014, 09:12 PM
0/11 ssssss768
Yeah id almost order it somwhere else tho menards doesnt stock it and a buddy ordered 2 sheets and one came with a huge crack in it
I dunno if you got a wall but even single layer would be 500 bucks for 7 sheets
And regardlessi feel like 70 inche long surfaces will still need bracing even if i got the really good stuff
Old 11-08-2014, 09:34 PM
SINTORMAN's Avatar
0/11 sssss4907
You can put in steps to make it stronger. Like bring in the wall 4" over 4" and then back 4" or something to make that 35" across. This is my wall. Ended up being like 6 sheets of 5'x5' iirc. Double all the way around and triple baffle.
You are totally right. Large cross-sectional areas are weak inherently so you either need to brace or break it up by stepping in etc... I'd ask local lumber yards on pricing.
Current Build:
#60sHereIcome
The Following User Says Thank You to SINTORMAN For This Useful Post:
Old 11-08-2014, 10:14 PM
A single thick brace from front-back/side-side/top-bottom in the middle of the panel is about as strong as doubling the thickness of the panel. I would rather have some internal bracing with good contact than a bunch of 2x4s that may be bowed and have poor contact with the wall and no clamping action.
Old 11-08-2014, 10:28 PM
0/11 ssssss768
Though the 2xs arw cheap they are very straight for the price
The main goal im shooting for is under 300 in wood costs. I plan on doing bracing with wood dowels on the sealed section i got about 7 3 footers so ill have quite a bit (sealed section will be 12 inches deep)
Then i got some prety thick angle iron for the joints
I think imma do some threaded pipe top to bottom in the ported section
I have plenty of screws and glue from the last 3 walls ive done i just dont think double laying is going to be cost effective in this instance
4 diameter 4 layer coil/ 8 layer coil. 03navi General Car Audio Discussion & Questions 6 06-04-2014 01:06 AM
4 layer coil in a 8 layer gap.Good or bad idea Groundcontrol General Car Audio Discussion & Questions 7 12-27-2013 01:31 PM
3" coils: 4-layer D1, 8-layer Q2 hurrication Speaker Accessories & Parts 5 08-11-2013 07:50 AM
t-line for a single 12" and single sheet of mdf? (VVME RD-12) graham Enclosure Discussion & Design Construction Help 0 06-13-2013 05:01 AM
wtt 2 4 in 8 layer coils for 4 in 4 layer coil marcotheclepto Car Audio Trader (WTT) 8 01-16-2012 08:51 AM
