Fiberglass resin or roll on bed liner - Car Audio Classifieds!
Old 11-10-2014, 03:17 PM
0/11 sssssss58
Default Fiberglass resin or roll on bed liner
I have been curious on what I should finish the inside of my new enclosure with. I always would use resin. That's Just how iv been building my boxes for a while. But now I'm seeing more people using a roll on bed liner? Any positive or negative review/input on using roll on bed liner for the inside of a vented enclosure?
Thanks!
Old 11-10-2014, 03:23 PM
davidrforbus's Avatar
0/11 sssss6030
Feedback Score: 59 reviews
I'm confused on why anyone would use roll on bed liner on the inside of a box? Resin makes the inside airtight and smooth. Bed liner is really rough so I don't see why it would help at all.
The Following User Says Thank You to davidrforbus For This Useful Post:
Haelmuscle (11-10-2014)
Old 11-10-2014, 03:26 PM
0/11 sssssss58
That's why I always stuck to using fiberglass. But I thought there was some magical new benefit of using bed liner because I see it here and there now.
Old 01-01-2015, 02:01 PM
The_Dealer's Avatar
0/11 ssssss212
The texture of the roll on bedliner is dependent on what type of roller you use. The ones that come in the kit are IMO one of the worst ones to use. I like using a small super fine foam roller like the ones here: Frame Roller | RONA. I don't have much experience with resin, but have had good luck with the roll on bedliner(rustoleum seems to be the best), but I mainly use it on the outside since I run a light bead of caulk the inside of the box. The bedliner is easy, cheap, and when done right looks awesome. It also protects your mdf from moisture.
You can pick them up at Walmart fairly cheap, you'll need 4-6 of them. I like to add a little xylene to thin it out(around 10-15% xylene to 85-90% bedliner). You don't want it super thin or runny, just thin enough to keep it from clumping. A lot of thin coats is key, I usually end up with 8-10 coats, then 2-3 coats to texture. By thinning it with xylene and using a super fine foam roller, it's easy to get a non textured finish. The texture comes from rolling it on after the last coat is almost completely dry. Use a brush to get tight corners. Kinda o/t, but I'll throw it out there anyways. When I do the outside of my boxes that aren't getting carpet, I'll do 8 or 9 coats like mentioned above then let it dry overnight. I lightly wetsand with 500 grit just to even it out and fix any screw-up's. I roll 2-3 light fast coats to throw some texture down, then use the bedliner in a spray can for my final texture, usually 2 spray cans worth(spraying about 12-14" from the box), waiting 5-10 min between passes. The end result is a decently thick nice even sealed coating, with a Line-X style texture. Not a box, but here's an example of an emblem I did using the technique mentioned above.
I usually spend between 35-40 to do an outside of a box, depending on the size. If you change boxes like underwear, roll on bedliner won't be too cost effective. I coat the boxes in my Jeeps since they'll eventually get wet, and I've never had an issue with the mdf swelling
Sent from my Samsung Galaxy Tab4 on 38's
How much resin and fiberglass mat do I need? Kcbme General Car Audio Discussion & Questions 14 09-20-2014 10:10 PM
fiberglass resin between baffles Gmanguy Enclosure Discussion & Design Construction Help 4 05-31-2014 12:21 AM
Help with the best deal on fiberglass resin got160s? General Car Audio Discussion & Questions 2 08-05-2012 07:43 AM
Good brand of fiberglass resin? davidrforbus Sound Deadening & Fabrication 29 03-19-2011 05:14 PM
Fiberglass resin ??? KHARPS General Car Audio Discussion & Questions 9 07-11-2009 05:03 PM
