Build in an 05 silverado 4 door? - Car Audio Classifieds!
Old 11-11-2014, 11:48 AM
Beatdown337's Avatar
0/11 sssss1535
Default Build in an 05 silverado 4 door?
Ive used the search button and looked through the build logs as well but I cant seem to find any examples of something either under or behind the seat in this truck. this is for my uncle so its just a single 10 so nothing big
Old 11-11-2014, 11:59 AM
doug118's Avatar
0/11 sssss4674
Better off buying a pre-fab box in that situation
Old 11-11-2014, 12:43 PM
0/11 sssss1535
Ouch! Not really what I wanted to hear as I was hoping to go ported tuned to a decent frequency. What makes you say that?
Old 11-11-2014, 01:07 PM
Todd Dupler's Avatar
Team SPL Farms
0/11 sssss5000
I have an sa8 in a ported box under the seat in my 01. Probably pretty similar. The bottom of the seat in mine is a bit flexible so it helped w having options on where to aim the sub. have mine ported to the side and it has better response w the sub pointed rear. Going to try sub/port both back next.
Started like this them turned it around to face rear. Have fun
01 Volkswagen Golf 2 door
Kenwood ddx470
Old 11-11-2014, 01:11 PM
Team SPL Farms
0/11 sssss5000
Prefabs are for lames. Even if a prefab is better than what i built mine is still better. Cuz i built it. But nah to each his own man.
Kenwood ddx470
Old 11-12-2014, 04:51 PM
0/11 sssss1535
Do you think theres room under there for a 10 ported. I was actually wanting to do something very similar to what you did there all the way down to how you have the port side firing.
So youre saying that its loudest with the port facing the back wall going towards the tail gate?
Old 11-12-2014, 05:44 PM
andy75's Avatar
0/11 ssssss788
Is it a real four door or and extended cab? Big difference in space available due to seat brackets.
Old 11-13-2014, 12:27 AM
0/11 ssssss249
this^ you would be better off if it is the ext cab. if it is the crew cab you have barely enough room for 1 10 ported but even worse your limited to a mounting depth of about 6 1/8 inches. there are behind the back seat boxes but the are even shallower i believe. How about a center console build?
Old 11-13-2014, 06:08 AM
Team SPL Farms
0/11 sssss5000
Sub rear ported to pass side right now. Rear and rear next try
Kenwood ddx470
Old 11-13-2014, 08:53 AM
0/11 sssss1535
its actually the crew cab (four door). if it helps id even be willing to try something downfiring even though that wasn't my first choice
tahoe door panels 2000/2006 yukon/escalade/silverado select127 Wiring, Electrical & Other Installation Equipment 12 01-29-2015 12:02 PM
06 Silverado door pods TEAM NEMESIS SCOTT Build Logs 12 08-01-2012 12:47 PM
2004 Chevy Silverado custom rear door pods and 5.25 Polk comps. hobbywerks Wiring, Electrical & Other Installation Equipment 1 01-24-2012 03:33 PM
Door panels in a OB Chevy Silverado TeamPSI (PSI Car Audio) 12 06-02-2011 11:55 AM
Idea for silverado door panels. oxsign General Car Audio Discussion & Questions 2 09-23-2010 08:28 PM
