RE calc VS Torres - Car Audio Classifieds!
Old 11-19-2014, 10:28 PM
0/11 sssss1882
Default RE calc VS Torres
Ok so to start off I know most calculators use different methods to determines an enclosures acoustics. I also know that placing anything in cabin changes the whole game.
My only problem is both of these calculators are widely respected but they gave me two totally different outcomes in terms of tuning and expected response with the same physical properties.
My question is, which do you feel would be more accurate for an design "on paper"?
Old 11-21-2014, 10:37 PM
0/11 sssss1882
Bumping it up. Trying to design some stuff for a friend and I'm getting completely different results despite the same input.
Need some advice please.
Old 11-21-2014, 10:40 PM
doug118's Avatar
0/11 sssss4674
I have a Mac so I can't use Torres but I really like Speaker Enclosure Volume Calculator
Old 11-21-2014, 10:53 PM
0/11 sssss1882
Thanks for the tip Doug. I'll check that out tomorrow.
Anyone else wanna offer some info?
Old 11-21-2014, 11:44 PM
0/11 sssssss31
Torres is more accurate, the re one doesn't account for sub I believe plus other stuff. I found a post a long time ago that explained everything and why they are off from each other.
I have had better luck with Torres
Old 11-22-2014, 12:38 AM
I've noticed that for vent length calculations, some programs don't account for the vent displacement. You also have to note if you select a "slot port" option how that's calculated; if, for instance, you have a 3"x20" vent area and the wrong dimension is used for the slot end-correction, you could be 8.5" off on the correct length because it assumes the 20" is the "slot" dimension and not the 3". It also gets tricky with long "slot" dimensions and end-correction factors anyway, and if the program has no way to compensate for this (and just assumes "length-1/2 dimension") the numbers will vary.
Old 11-22-2014, 06:51 AM
0/11 sssss1882
Makes sense.
I see nothing but honest advice coming from your posts SPL. I appreciate it a lot.
Which program would you recommend? Mind you I don't have $xxx for a real modeling simulator.
Old 11-22-2014, 07:52 AM
Haelmuscle's Avatar
0/11 sssss1819
I suggest using you're own calculations, measure height X width X depth then divide by 1728 and that's it, now take that cubic ft number plug it in any online calculator such as the 12volts and only calculate the port displacement so you can get the true net volume, aeroport usually they are very thin so 6" aero at 25" long will be 3x3 (half the dimeter squared) x 3.14 x 25" long devided by 1728 and that's your displacemt which is .40 cu ft!
For square vent like 6"x6" at 25" long just multiply height X width X length then devide by 1728 and that's it!
Kindest Regards.
The Following User Says Thank You to Haelmuscle For This Useful Post:
crownvicon26's (11-22-2014)
Old 11-22-2014, 09:01 AM
0/11 sssss1882
Goos looking out hael. That's the simplest explanation I've ever seen.
The Following User Says Thank You to southernbass For This Useful Post:
Haelmuscle (11-22-2014)
Old 11-22-2014, 09:07 AM
0/11 sssss1882
Now that I think about it, how would we calculate the tuning on our own?
need somebody who has the torres box calc ,I have a macbook Mnorwood01 General Car Audio Discussion & Questions 9 04-03-2013 06:23 PM
can anybody with torres calc tell me what my box net is and tuning.??? Mnorwood01 General Car Audio Discussion & Questions 6 02-24-2013 05:47 PM
Need somebody who has the torres box calc to punch these numbers in for me, Mnorwood01 General Car Audio Discussion & Questions 2 11-10-2012 08:14 PM
Need somebody who has the torres box calc to punch these numbers in for me, and give Mnorwood01 Enclosure Discussion & Design Construction Help 0 11-10-2012 02:56 PM
Calc II integrals MopaRBumpiN Academic Section 14 11-01-2010 08:12 PM
