woofer box for two AB XFL1544 - Car Audio Classifieds!
Old 11-30-2014, 10:40 AM
0/11 sssssss16
Default woofer box for two AB XFL1544
I was needing help after researching around on what I should do with the port size on my box. Internal measure are 41x18x17, around 6cubic feet. I have 4 round ports 4" in diameter. I want a good hz but have been debating. I have only 18" in height so I was wondering if four 4x15 ports would be ok and what that would be tuned to. I have not done round ports before. That gives 3" between the bottom of the port and the bottom of the box. Is there a noticeable difference in sound between 4x15 and 4x14?
They'll be receiving 1500-1800 watts together. The subs are facing the rear, the ports are facing upwards. Need a little direction.
thanks
Old 11-30-2014, 11:26 AM
0/11 ssss31257
there's no noticeable difference. 14 vs 13"
33hz is the go-to frequency.. (best bet)
Old 11-30-2014, 11:41 AM
0/11 sssssss16
So would 4x30 (two 4x15) be enough port space in 3 cubes for 33hz? Or is that a few Hz higher. I have 18" to play and 15" is almost pushing it, so if i need to gain more port i have to put a 90 degree or a 180 to bend at least one port per sub back upwards. This will be my largest setup, my last setup was two 12s on 1200 watts at 42hz with a box i did not build myself. So i'm trying to learn and gain as much info as I can. Since the box is already built, I have ports left to play with. Thanks for any help sonic
Old 11-30-2014, 11:55 AM
0/11 ssss31257
4 3" will need to be 21.5 to 22" long
Old 11-30-2014, 12:31 PM
0/11 sssssss16
I have four 4" circles cut out. Need the length of what to cut my pvc pipe to.
Old 11-30-2014, 01:19 PM
0/11 ssss31257
make the ports 2" shy of the bottom.
the tuning will be around 38-40 hz..
honestly,
my suggestion at this point is to stop what you're doing and just buy this;
Q-Power QBOMB15V 15-Inch Dual Vented Subwoofer Box Enclosure : VMInnovations.com
tez4life (11-30-2014)
Old 11-30-2014, 03:31 PM
0/11 sssssss16
I would of bought that box if I would of joined here a few weeks ago, I built this out of 1" MDF, all I have to do is cut the ports and throw the subs in and see how i sounds. That box is 4.6 cu ft and mine is 6.0 cu ft. I measured my trunk and went as large as I could. It's in a crown vic as wide as I could make it. I could of went with more height. I have a 5ft piece of PVC that I can equally cut into 15" lengths. It's hard to find a prebuilt box to drop into the crown vics lower trunk space.
Old 11-30-2014, 04:21 PM
0/11 sssss2148
Feedback Score: 26 reviews
What year Vic? I had a 2004 for 6 years, had a dual 15" box built for me by a semi local guy for a pair of DC subs, it was subs up, port back, 6 cubic feet net (after slot port displacement) tuned to 32hz with about 70 square inches of port....box was externally 40"x 20" x 20" and dropped in without any issues, and still had plenty of room.
Just wondering why your length and depth are so low? I know the crown Vics (pre 1998) had slightly smaller trunks though. Really with those subs you want more box volume, and port area if you can, like 7 cubic feet net for the pair.
Id fire subs and port up, have 3 friends that all had Crown Vics that did that and all were happy with the output. Trunk lid going to rattle but a little deadening and spray foam helps.
Products Menu That will help you figure out how long to make your ports to get your tuning right.
Old 11-30-2014, 04:23 PM
0/11 sssss2148
(4) 4" round ports in 6 net would have to be 16.5" long for 35hz and 18.8" long for 33hz....for them to be 15" long, that would put you at a tune of 37hz....
Old 11-30-2014, 04:37 PM
0/11 sssssss16
Mine also is a 2004 LX. Externally my box measure 42x19x19. I built the box for mofos at first then decided to go with the XFL 15s which I'm glad about.
My box has the subs facing the rear and the ports facing upwards, but I can face subs up and have the port forward or back with room for it to breathe still. Since you all had good results I might have to give that a try.
Did you just deaden the trunk lid or did you do the whole trunk. On my 02 I had if you pull back the carpet toward the rear sides you can see the ground from inside the trunk. The trunk rattled a good amount with the 12s I had in there in 4.5 cubes.
I think I'm going to get two 180 degree bends and extended two ports an extra 6-8 inches for lower tune. Need to make my final decision. Plan on completing and installing next week. New deck, speakers, amp for mids and highs, amp for woofers and new subs.
Box for 8" woofer.... West1 General Car Audio Discussion & Questions 2 11-24-2012 07:24 PM
XFL1544 Basket (old style) big_grasshopper Wanting to Buy (WTB) 0 10-11-2012 05:16 PM
woofer tester and bass box lite usampsman Wiring, Electrical & Other Installation Equipment 8 10-03-2012 08:48 PM
(2) american bass xfl1544 psychoacoustics 15" Subwoofers 60 07-24-2011 10:49 PM
Box suggestion dc/fi woofer 808runner Enclosure Discussion & Design Construction Help 1 04-16-2011 06:46 AM
