Big Aero Port in a wall? - Car Audio Classifieds!
Old 12-03-2014, 06:06 PM
0/11 ssssss386
Default Big Aero Port in a wall?
Anyone on here ever tried a large aero port in a walled set up vs. the typical slot port on the drivers side? I have seen both done, but was hoping someone had done a direct comparison in their build before.
I have a walled tahoe with 4/18s and currently have a large slot port now...but I was thinking of doing a remodel on the baffle and trying something different. Its mostly for music competition more than burps so I am kind of chasing numbers. I know most people say the slot ports are best for walls and competition, but I wasn't really happy with the output. It was taking a little over 20K to get a 160 out of it with meter on dash outlaw style. Didn't seem very efficient to me. In a previous set up that was not walled I had good luck with big aeros with flares. Just looking to see if someone had some experience with that in a wall?
Thanks
2013 and 2011 Midwest SPL Extreme Trunk Champ
94 Honda Accord
Two DD 9915 SC front firing out of the trunk
2 DD M4a's
Old 12-03-2014, 07:12 PM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
I haven't tried both but once I went large aero I never went back. A 14" port at 10" long tuned to 30hz FTW
This was a nonwall box
Plus you can go really small on port per cube with no noise. Efficiency FTW.
Current Build:
#60sHereIcome
The Following User Says Thank You to SINTORMAN For This Useful Post:
IS300IAdeathRow (12-03-2014)
Old 12-03-2014, 07:24 PM
doug118's Avatar
0/11 sssss4674
I can get you very large metal flares and I believe ChaunB can also. I've never done a large aero in a wall but when I went from aeros back to slot port, I almost immediately went back to aero
The Following User Says Thank You to doug118 For This Useful Post:
ChaunB3400 (12-04-2014)
Old 12-03-2014, 07:29 PM
HiloDB1's Avatar
0/11 sssss3158
Speaking of big round ports
Old 12-03-2014, 08:03 PM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
Can I has?!
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 12-03-2014, 08:41 PM
0/11 ssssss177
I've wondered if sono tubes would work
Old 12-03-2014, 08:43 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
I know I've seen it.....giant 5 ft dia aeroport and don't remember the subs but was on here awhile ago.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 12-03-2014, 08:44 PM
0/11 ssss12531
If they're thick enough they don't flex.
e46, whatcha think?!?!
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 12-03-2014, 08:46 PM
SPL Farms
0/11 sssss5706
Sono tubes work great. I use 8" sono for most of my builds currently 2 of them in the 4runner
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 12-03-2014, 08:52 PM
SINTORMAN's Avatar
0/11 sssss4907
Anything round and resin will stick to will work lol.
or not round for that matter. I've used a pvc fence post for a port before. Worked pretty well.
Current Build:
#60sHereIcome
What happens if aero port is to close to interior wall. Mnorwood01 General Car Audio Discussion & Questions 10 11-18-2013 03:46 AM
10" aero port coming today for the big boy zv3 18s, wat should i expect output wise ? Mnorwood01 (Sundown Audio) 44 07-15-2012 01:02 PM
Aero or slot port for wall thecartel Enclosure Discussion & Design Construction Help 13 10-29-2011 02:04 PM
how far does an AERO port need to be from the back wall? SacTownBully84 General Car Audio Discussion & Questions 3 06-24-2010 12:54 AM
Big Aero Port Flares - 9 and 10 inches. *PICS* Tinted Speaker Accessories & Parts 4 12-06-2008 04:57 PM
