Toyota Tacoma Ported enclosure - Car Audio Classifieds!
Old 12-06-2014, 01:59 PM
0/11 ssssss463
Default Toyota Tacoma Ported enclosure
Putting this together for my new truck. 2015 Tacoma double cab. Was able to get 1.4cuft net after all displacement/port/bracing. Installing 2 alpine type r 8"'s. Tuned to 38 Hz.
Old 04-22-2015, 11:27 PM
0/11 ssssss102
so this box is going behind the back seats? how much room do you have back there? I'm in an 06 regular cab so I'm trying to come up with ideas for a build..
Old 04-23-2015, 01:28 AM
0/11 ssssss245
I've put two solobaric 12's behind a back seat of a ranger reg cab. You can use the back wall of the cab as part of the enclosure and reinforce it with fiberglass and some wooden ribs and a cut out divider. You can get all into the corners with fiberglass for alot more airspace.
Old 04-23-2015, 06:55 AM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
Nice work on the box so far
Old 04-23-2015, 08:37 AM
0/11 ssssss463
I used two Skar VD-10's in this box and it sounds great. I believe it's tuned in the low 30's and plays well below that. Used an alpine 600.1 for power.
Old 04-23-2015, 10:37 AM
Really nice fab work on that enclosure. So many angle cuts, lol.
Old 09-14-2015, 11:20 PM
Killer Audio's Avatar
0/11 ssssss604
Did you ever finish this? I have an 09 and I'm looking for a box design
Old 09-15-2015, 07:53 AM
0/11 ssssss463
It's been done. Actually have a new truck now. It's sitting in my garage. Sounded great. Had to use semi shallow subs. I used skar VD10's.
Old 09-19-2015, 09:31 PM
0/11 ssssss102
Have any pictures of it installed? looks good
1997 toyota tacoma Skar and Sundown unarmedone Build Logs 0 10-08-2014 12:51 PM
Ported 8" sub enclosure for 2004 Tacoma 4 door socalxj General Car Audio Discussion & Questions 1 09-08-2013 03:58 PM
Toyota Tacoma Ext Cab ..ZVX 18 dcarcstms Build Logs 0 03-16-2013 08:47 PM
02 Toyota Tacoma Xtended Cab 30Hertz Miscellaneous Build Logs 3 10-12-2011 01:21 AM
Toyota tacoma 4 e8s box build statonburrell Build Logs 7 09-18-2009 08:25 PM
