Interchangable port help - Car Audio Classifieds!
Old 12-11-2014, 02:33 AM
0/11 ssssss247
Default Interchangable port help
My Box is going to be 18.5 cubic ft after displacement
Trying to make 3 ports one 29hrz, 35hrz, and 40hrz
Just need help that's all ports will very in size...and built form mdf 1/2" wood
Or I have a couple of 8" aero ports with a length of 21" that can be cut down to size
Thanks
Old 12-11-2014, 03:50 AM
What subs and how many? For the 8" diameter aeros you'll need at least two per port inset to get a fair amount of port area, possibly more.
Old 12-11-2014, 07:22 AM
0/11 ssssss247
There 4 18s....and I have and endless amount of ports at my job
Old 01-07-2015, 09:33 PM
0/11 sssssss23
im curious to see how this turns out. im planning on doing an interchangeable port as well
Cartunz 3X show 6-24-2012 $500 for loudest non Port or Super Port score bdufner Competition Corner 2 06-16-2012 07:29 AM
Box Build, 4 SA-8's, bedliner, interchangable ports DL Designz Build Logs 14 12-12-2011 09:49 PM
3 AQ15's Interchangable Port? cotyballs Enclosure Discussion & Design Construction Help 4 04-03-2011 08:22 PM
interchangable port help fox_racin4 Enclosure Discussion & Design Construction Help 0 09-07-2010 06:49 PM
