Box choice 4th order or big ported box in Cadillac - Car Audio Classifieds!
Old 12-17-2014, 02:24 PM
0/11 ssssss109
Default Box choice 4th order or big ported box in Cadillac
Wondering if any body could help me on a choice of box styles.I have a 99 Cadillac deville and have 18 or 19 ft of space in the trunk. I puting a sundown 4500 on two 15 either dcxl or sundown zv4 and 300amp atl and 4 battcap 2000 batts. I listed to rap and like low bass ,my ? Is would I get more out 4th order port threw the arm rest or back deck or just run a ported box build and face woofers facing trunk or tag and ports threw back deck from top of the box. I really not trying to take up 10cubic feet or less.
Old 02-09-2015, 06:30 AM
0/11 ssssss118
where did u get that measurment on ur trunk from? i have a 2000 deville i think my trunk is bigger than urs and im pretty sure its not 18 cubes
Old 02-09-2015, 07:38 AM
briankeith1007's Avatar
0/11 ssssss374
Default I can help
What's up man,my name is Brian.Do you want to build a box you can take out or a in trunk build?
Old 02-09-2015, 08:36 AM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
Your going to use every bit of room if you try 2 15's in a 4th. And ported will use close to 10 cubes after port displacement. Your port will need to be huge if its a 4th. Alot bigger then the ski pass or deck. Ported trunk wall would be tight but can be done
Old 02-09-2015, 09:48 AM
0/11 ssssss109
Wright now I'm stuck between what I'm going do now in far as bass far as box and subwoofer size now.I forgot bout the air ride system and I have 24 forgi and I know air ride snot going handle the weight of box two sundown zv4 and 4 batt and Amps.
So don't know what I'm going do now . Go smaller or lighter speakers. Ideas please -I also thought (2) sundown x 12s Big ported box with the woofer facing rear trunk and port threw back deck
Old 02-09-2015, 09:58 AM
Authorized Vendor
0/11 ssss14115
Wright now I'm stuck between what I'm going do now in far as bass far as box and speaker size naw. I forgot bout the air ride system and I have 24 forgi and I know air ride snot going handle the weight of box two sundown zv4 and 4 batt and Amps.
2 12" neo drivers
Old 02-09-2015, 10:18 AM
0/11 ssssss109
Need subwoofer idea to help on weight
Old 02-09-2015, 10:27 AM
Authorized Vendor
0/11 ssss14115
IA wardens?
Old 02-09-2015, 10:34 AM
0/11 ssssss109
Are they lighter then the sundown zv4 and holdup to sundown 4500
Old 02-09-2015, 10:37 AM
Authorized Vendor
0/11 ssss14115
about 15 lbs lighter each. rated 3500 each
they were just the first neo's that came to mind that are easily available
Turning my ported box into a 4th order for 4 sundown zv3 18"s Mnorwood01 General Car Audio Discussion & Questions 28 09-30-2015 06:35 PM
Help with 4th order sub choice. StatingROBIN General Car Audio Discussion & Questions 15 05-09-2013 05:06 PM
4 order box idea for 2000 Cadillac deville dirtysouth basshead Enclosure Discussion & Design Construction Help 4 04-28-2013 11:07 PM
4th order or ported box Chance0161 Enclosure Discussion & Design Construction Help 6 10-02-2012 12:29 PM
