So, I guess its time to to design.... - Car Audio Classifieds!
Old 01-04-2015, 08:04 PM
joebobclark's Avatar
Your Moms New Boyfriend
0/11 ssssss985
Feedback Score: 22 reviews
Default So, I guess its time to to design....
I have some subs put together (feel free to check out the sub build here) and the Blazer is pretty much ready (build log so far here)....
The weather will be nice again here (NH) soon enough and I want to go to shows/comps this year... Time to finish what I've started.
Subs are broken in some, still stiffer than I thought they would be, but that's ok! Pulled T/S specs with my DATS, but I feel some are askew from the low output from computer testing coupled with stiff suspension...
Average specs I got are:
Fs - 33hz
Qms - 6.316
Vas - 48.77 L (1.722 cubic feet)
n(0) - .13%
Mms -262.8 grams
Re - 1.72 ohm (DVC in series, ~1 ohm each)
Qes - 1.215
SPL - 83.21 db 1W/1m
SPL - 89.89 db 2.83 Vrms
Cms - .09 mm/N
Piston Diameter - 279.4 mm (11.5 in)
Z(max) - 10.64 ohm
Qts - 1.019 ( I think this is high, probably be .5-.55 in factory specs)
Le - .508 mH at 10kHz
BL - 8.68
I have 2 15's ready to go... Dave at PSi built the softies, I put everything together...
I have a SS Rubicon 2500 for now, subs were built for 1000-1250w rms each. Will run at ~1 ohm before rise.
Will be sealed wall, B pillar. Im looking at 38 inches wide (to stay between the wheel wells) and 32 inches high (false floor already built), I can go 45-50 inches deep, giving me ~35 cubic feet of space to work with.
At first I was going to do standard ported, with a "flared" port, subs mounted inverted on "flared" portion of port. Something like this...
But I have also been thinking 4th order.... Model it up in BBP and it looks good and flat for 1 driver, but if I do 2 drivers the results differ greatly and not for the better... Shows ~3cuft sealed and ~8cuft ported at 54Hz? iirc for 1 driver and ~6cuft sealed and ~16cuft ported at ~70hz iirc for 2 drivers.... Main question here is am I doing something wrong for 2 drivers? Box volume makes sense (doubled for 2) but why the higher tuning and horrible plot? It comes to 2.75:1 ratio, so that seems right...
Secondly, BBP doesn't make it easy to get the port worked out... wants me to have a small area, long port, I would rather have a large area, short port... Thinking 2.75-3:1, tuned to around 50-55hz....Suggestions? Opinions? I'm open to all!
Started throwing around the idea for twin TLines (seperate ones for each driver).... Need ~132 sqin of port area per 15. 32-33hz tuning (qtr wave) would be ~8.75/8.5ft long... seems doable with my working area.... Imagine 2 boxes like this (but bigger, lol), next to each other, standing on end (port at top), then sealed wall paneling...
Also open to other designs? Folded horn, maybe? Kinda want something different, but impressive loudness...
Any help with designs is greatly appreciated! Will pay if necessary...
Thanks in advance!
2005 S10 Blazer 2-door
**** Under Construction****
Old 01-04-2015, 08:30 PM
0/11 sssss1085
Feedback Score: 23 reviews
A qts over 1 is pretty common with stiff suspensions and aluminum coils used on less powerful motors.
Old 01-05-2015, 08:21 PM
0/11 ssssss985
So, after playing on paper today, I think I have an idea for a 4th, 4 cft sealed and ~11.5 cft ported, with changeable port (wanna try 45, 50, 55hz ports or change them as needed) 20inx10in, so 200sq of port, just over 17sq per cft (too much?)
This sound pretty good? Can (will) anybody help with a Sketchup? I can draw it out on paper, but have NO Sketchup skillz, lol....
Old 01-06-2015, 07:44 PM
0/11 ssssss985
Anyone? Any input? Opinions, criticisms, lies, crazy stories?
Old 01-06-2015, 08:15 PM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
i would be willing to make you a sketch as long as you have clear enoufg directions as to what you want
Time to move on, time to say good bye Silver-N-black Off Topic Chat 18 06-20-2014 09:14 AM
Whats the turn around time on a design etznova General Car Audio Discussion & Questions 7 10-01-2012 10:02 PM
Long time lurker, 1st time poster budgophile New Member Orientation 3 08-30-2012 02:38 AM
I will be unable to build/possibly design for some time Pioneer~Saturn General Car Audio Discussion & Questions 20 01-10-2012 07:47 PM
Long time listener, first time caller danssoslow New Member Orientation 7 09-16-2009 12:28 PM
