4th order wall questions - Car Audio Classifieds!
Old 01-11-2015, 04:55 PM
0/11 sssssss25
Default 4th order wall questions
looking to wall my 88 suburban and would like to go 4th order with 4 Fi BTL 18s (xmax coils) what i am wondering is how big do i want my sealed section? i am thinking ratio wise a standard 2:1 to keep things balanced. i want a good blend of SPL numbers and still be able to demo with low lows.
space i have to work with is 50.25 wide, 38 tall and 91 long.. so space is a plenty. power will be an AB 1100.1 with plenty of AGM available (600 pounds worth) and 2 300amp alts
additional question: would i want the sealed section on the back wall or like a saddle bag setup on the sides? subs will be inverted motor side visible
Old 01-11-2015, 05:04 PM
toad559's Avatar
0/11 sssss1508
You can do a 3:1 ratio. Theres a few guys here that has simular build as to what your doing. You should have enough room to make all 4 18" firing foward I to the ported chamber. Seal sealtion will vary. Every setup is different. Theres some guros here that can help you more. Try finding an old thread titled. (4th order. Why some people so quit)....tons of Info. Super long thread.
Old 01-11-2015, 05:25 PM
0/11 sssssss25
wow thats a ton of pages.. i have some reading to do! thanks
Old 01-11-2015, 06:30 PM
0/11 sssss1411
88 should be square body like mine - i did c pillar wall 4th did one side subs other side ported 3;1 ratio aparently there is a formula for sealed side that dictates your sealed resonance hz tuning vs how much cubic ft you have - fourm member haleel muscle told me mine cause idk how to figure that part out. i tuned my sealed side to what i thought was 41/2 ish hz yet somehow my burb peaks at 34hz - lotts of pix and info in my build log - also you trying to build inside the viehcle - or do a slide in box ?
4th order or wall? i.m.live General Car Audio Discussion & Questions 1 05-12-2014 05:06 PM
4th order wall or flat wall Dirtbikerrob Enclosure Discussion & Design Construction Help 9 03-05-2013 10:25 PM
4th order questions maverickdog8 Enclosure Discussion & Design Construction Help 7 05-16-2012 09:47 PM
ported wall or 4th order wall jmkanek Enclosure Discussion & Design Construction Help 12 05-12-2012 09:37 PM
4th order wall? tommytee General Car Audio Discussion & Questions 16 01-27-2012 04:01 PM
