Should I Port My Sealed Box? - Car Audio Classifieds!
Old 01-14-2015, 09:30 AM
0/11 ssssss201
Default Should I Port My Sealed Box?
my current set up is 3 t3 audio t1000 12's powered by 2 mb quart dsc2000's strapped at 2.6. and i ended up going with a sealed box and lately i kind of wish i would have gone ported. the sound is a little on the punchy side and the lows really aren't where i want them to be.
with my available airspace, would using an aeroport be an option? i'm looking to tune in the low to mid 30's.
box dimensions are 38" long on the bottom, 42" long on the top, 16" deep and 12" tall. the subs are facing up and the top of the box has a double baffle. the box is built out of 3/4" mdf.
Old 01-14-2015, 10:18 AM
Thelonewolf's Avatar
CACO SLACKER
0/11 ssssss597
you need around 7 cubic feet
you have about 3.5 gross
Old 01-14-2015, 10:31 AM
0/11 ssssss637
Not sure what kind of vehicle this is in. If it's a trunk try facing them toward the rear.
Old 01-14-2015, 10:33 AM
0/11 ssssss201
it's in a 2008 scion xb.
Old 01-14-2015, 10:45 AM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
Feedback Score: 49 reviews
I'd do 2 in a ported since you won't have the room for 3.
Old 01-14-2015, 10:52 AM
0/11 ssssss637
I would try a singe 4" port on the passenger side between 8"-9.25"
Old 01-14-2015, 11:02 AM
0/11 ssssss201
any idea where that would tune me to?
Old 01-14-2015, 11:10 AM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
You don't have nearly enough airspace to try and port those woofers. If you did it would sound like duck farts. You should just build a new enclosure with the right volume for a ported setup and enough port area to sound right. A single 4" port will have so much port velocity in that small enclosure with way too much cone area for the port to work properly. You'll have port noise constantly and it will probably be a complete waste of time and energy.
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 01-14-2015, 11:12 AM
0/11 ssssss637
I'm by no means an expert. But the aero rules of thumb are bs. My 4 inch aero suggestion was in reference to a box built to suit.
Old 01-14-2015, 11:34 AM
0/11 ssssss201
maybe i'll throw in some polyfill and see if it'll help a little.
rear deck port- pros and cons. in sealed trunk lowlows General Car Audio Discussion & Questions 0 07-25-2013 11:56 PM
i only hit a 145db sealed and 146.2 with door open. see vids. help me with my port... kickerfanatic General Car Audio Discussion & Questions 22 08-22-2011 09:18 AM
aero port box for 4 sa-8's, too much port? Dbmonster (Sundown Audio) 4 08-11-2011 02:08 AM
Small Ported box or Sealed box Beatdown337 Enclosure Discussion & Design Construction Help 9 05-27-2010 03:17 PM
