Any input on this 6th order design? (with sketchup images! woot woot) - Car Audio Classifieds!
Old 01-24-2015, 10:05 PM
0/11 ssssss535
Default Any input on this 6th order design? (with sketchup images! woot woot)
Any input?
Equipment:
4x SA-10's at 1ohm
SQ2200 (will upgrade in the near future to 4kish)
Please note, I didn't include a couple things in the sketchup, but they are factored into torres.
-12x 2" diameter 7.25 tall wooden dowels from the bottom up to the baffle
-steel bracing on the upper chamber
-top side port walls (they will only be 1 inch to start, I'm figuring I will have to adjust length/port area)
Specs:
Lower Chamber
-4.31 ft^3 net
-port area 30.5 in^2
-port area per foot 7.07 in^2
-Port ratio 1:7.63
-Tuning 28.44 Hz
Upper Chamber
-8.42 ft^3 net
-port area 198 in^2
-port area per foot 23.52 in^2
-port ratio 1:1.64
-Tuning 59.17 Hz
This is my first time using sketchup, pretty awesome program.
Old 01-24-2015, 10:35 PM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
Lower tuning in upper chamber by reducing port area to about 120-140"
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 01-24-2015, 10:37 PM
whats it going into?
Old 01-24-2015, 10:39 PM
0/11 ssssss535
Do you think the upper tuning is too high? Or just that there is too much port area? 80INCHES and GPCustoms both told me to go big with port area (22+ per cube) and then shrink it if its too much. From what I understand you want more than the "standard" 16 per cube on the large side with a 6th order, since I don't have to worry about "losing control" of the cone.
2008 Grand Cherokee from my build log.
Old 01-24-2015, 10:41 PM
I'd run it the way you have it and tune from there.
Old 01-24-2015, 10:45 PM
0/11 ssssss535
Awesome. Appreciate your input Korey.
4th order design sketchup stssilverado Enclosure Discussion & Design Construction Help 16 03-02-2013 12:32 PM
NEW KORN album is out!!!! woot woot korn4life Off Topic Chat 2 12-11-2011 08:19 AM
Woot NPHagert General Car Audio Discussion & Questions 89 08-23-2011 09:14 PM
8 More Weeks Woot Woot Parker G General Car Audio Discussion & Questions 35 08-31-2010 12:56 AM
woot off SPY Off Topic Chat 4 04-27-2010 08:23 PM
