Best Way to Tune Your Enclosure and Set Gains Based on your Music Library - Car Audio Classifieds!
Old 02-02-2015, 04:07 PM
jeffdachef's Avatar
0/11 ssssss440
Default Best Way to Tune Your Enclosure and Set Gains Based on your Music Library
This is a basic tutorial on how to find out your range of
frequencies you need to hit to help you tune your enclosure and also how to properly use a proper test tone to gain match based on your music choice rather than just guessing or using a random 0 db test tone you normally find online and losing out on some good output.
The video will also show you how to know if your music files are clean or filled with clipping and distortion.
https://www.youtube.com/watch?v=flu6KsCqLS0
Use in conjunction with response graphs of winisd to get the bass response you want out of your system with your enclosure design. As you know, not all subs will have a flat response in a ported box, there are tradeoffs you have to make especially if you have space constraints.
Using a dd-1 to set gains? rjtrapp (db-r) 293 02-04-2014 06:21 AM
What do.you use to.set your.gains? kurupt305 General Car Audio Discussion & Questions 21 08-19-2012 12:31 AM
Best way to set gains? Shakindablock General Car Audio Discussion & Questions 12 09-23-2011 03:04 PM
How do you set your gains? hornedfrog1985 General Car Audio Discussion & Questions 32 10-19-2009 05:08 PM
How Do YOU Set Your Gains? RidnClean General Car Audio Discussion & Questions 62 02-26-2009 07:37 PM
