Sub & port placement - Car Audio Classifieds!
Old 02-07-2015, 12:56 PM
0/11 ssssss308
Default Sub & port placement
So I'm decided to take my back seats out my crew cab for my next project this summer...which direction is best to face the subs and port
Old 02-07-2015, 01:17 PM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
Highly dependant on how much of the crew cab space you plan to use
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 02-07-2015, 01:27 PM
0/11 sssss1393
Window line or wall? How many Subs and what size
Old 02-07-2015, 02:15 PM
0/11 ssssss308
Definitely not a wall
Old 02-07-2015, 03:04 PM
SPL Farms
0/11 sssss5706
Wall it.... you really do want to... I mean, you are giving up the back seat already, might as well make the best use of the space possible....lol
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 02-07-2015, 04:55 PM
Kcbme's Avatar
0/11 ssssss526
I asked the same thing when I took my back seat out and most of the people said this:meter loud= port on drivers side,louder for driver= port to passenger side(I didn't hear a ton of info on port up or forward so not sure about them).I went with passenger side port because I built for daily, just make sure you leave room for port to breath and get ready for that door to take a beating(mine is fully deadened and ratchet strapped shut to the other door and it still moves a ton.As far as sub orientation it was either subs up or facing forward, I chose on top of box so a drunk person didn't recline into sub and mess them up.
As far as wall or no wall, now that I didn't wall it I wish I had I mean its nice to be able 2 look out your back window when backing up or 2 check your blind spot when changing lane but I drive a van for work with no back windows and have not had a problem driving it,so I would say wall it but that's just my thoughts.Also you wont have to deal with the annoying back window buzz/rattle trucks seem to get when loud and as much roof rattle(both my lights in headlined broke within a month of install). Plus you will be louder
2001 suburban
2.8:1 4th
4 db drive wdx 7k 18s on 2 crossfire 8ks
Old 02-07-2015, 06:57 PM
0/11 ssssss308
i dont want to wall because i still want to be able to see out my back glass and two i want a build an amp rack with plexiglass in the area also
Old 02-07-2015, 07:56 PM
Kcbme's Avatar
0/11 ssssss526
That's understandable I was the same way, and the amp rack sounds sweet. Any idea what size subs and how many you are going 2 run? Also If your anywhere near New Orleans or Baton Rouge I will be going down there for Mardi Gras hopefully, so I can give you demo if it helps you at all.
2001 suburban
2.8:1 4th
Old 02-07-2015, 08:03 PM
twizt3dfuc's Avatar
TEAM FSMD FOUNDER
0/11 sssss1372
Subs up, port up. That's what I've alway seen to be loudest. Had to maxximus 18s on 2 sampsons in 2010, in a 98 silverado that poor poor back glass. But it sounded great, much better than sub up port side or all firing foward.
TEAM DURTY POWA!!!
Compounding Pharmacy Extraordinaire
My Cream Makes You Stop Hurting
Old 02-07-2015, 08:09 PM
Kcbme's Avatar
0/11 ssssss526
I had a team mate trying to tell me this too but when I did research it seemed no one had any info on it. So sub up port up was better for daily? I wanna rebuild my box with birch to save lil weight and was thinking of changing port but didnt know what way,happen to have any pics? Sorry for thread jack op.
2001 suburban
2.8:1 4th
port type/ port placement from rear hatch Joe562MMA General Car Audio Discussion & Questions 1 05-26-2013 02:26 AM
port placement hdman87 Enclosure Discussion & Design Construction Help 4 10-15-2012 11:02 PM
best sub/port placement statonburrell General Car Audio Discussion & Questions 3 07-18-2010 09:30 PM
Need help with port placement. themgators511 Enclosure Discussion & Design Construction Help 6 06-23-2010 04:12 AM
Sub and Port Placement Help undeadxsunshine Enclosure Discussion & Design Construction Help 4 03-27-2010 06:27 PM
