Box suggestions for 2 X-15s. - Car Audio Classifieds!
Old 02-07-2015, 02:26 PM
davidrforbus's Avatar
0/11 sssss6030
Feedback Score: 59 reviews
Default Box suggestions for 2 X-15s.
Just got myX-15s in today. Starting to think about the box Imma build. Going in a extended cab ranger. I can built as big as needed. Don't want to wall it but I will. I'm almost positive it'll have to be subs and port forward. My max dimensions are 49x 16x x30. Tuned low of course. I'm gonna run at least 3k to the pair. On sundowns website it suggests 4.5 cubes each. Going by that gonna be my best bet?
Old 02-07-2015, 02:39 PM
massivespl's Avatar
0/11 sssss8409
Wall it
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 02-07-2015, 02:44 PM
0/11 sssss6030
Originally Posted by massivespl View Post
Wall it
I've got no problem with other than loosing all sight out of the back window. If I did that I'd probably have to get a backup camera.
Old 02-10-2015, 12:08 AM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Get with Ryan1126. He designed a box for my x15's.
Btw...any pics of them?
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 02-10-2015, 12:39 AM
KickinBlazer's Avatar
0/11 sssss1122
you can go as small as 3.75 cube per sub but it will take more power to get them to peak performance upwards of 2krms each....but 4 cube would be ok tho you might need a little more power...sundown specs wont take a whole bunch of power to get loud
if its to loud your to old!
Old 02-15-2015, 10:04 AM
0/11 ssssss339
Sub up port up, keep the distance from bottom of box to woofer the same as woofer to roof, 3 ports 1 on each side of sub's & one in middle. Tune how u wish enjoy musical notes loudly
New Box Suggestions PaCiFiKbAllA Enclosure Discussion & Design Construction Help 14 01-14-2012 12:13 AM
box suggestions for buick sedan with two DC 15s buickman Enclosure Discussion & Design Construction Help 3 11-06-2011 12:03 PM
how does this box look/ suggestions michigancapri92 Enclosure Discussion & Design Construction Help 1 07-23-2011 05:31 PM
Amp suggestions, (2) SA 15s tez4life (Sundown Audio) 5 02-19-2011 11:07 AM
box suggestions Nudels Enclosure Discussion & Design Construction Help 6 07-24-2009 08:59 PM
