Box Comparison Question - Car Audio Classifieds!
Old 02-10-2015, 04:48 PM
tntahoe's Avatar
0/11 sssss1196
Default Box Comparison Question
If I wanted to compare how a sound performs in a sealed versus ported box, would i use the same net volume in each case. So for instance I build a 1 cft sealed box, would I need to build a 1cft ported box? Im assuming this are minus the displacements and such.
Old 02-10-2015, 04:57 PM
0/11 sssss1882
Apples to oranges in my opinion. But generally speaking, I think you're on the right track.
Its kind of a toss up seeing as how sealed "tuning" is typically 40hz+ from my understanding. I don't see many ported enclosures tuned that high unless its bass boxing/competition use.
Old 02-10-2015, 04:58 PM
mega fatty
0/11 sssss6008
No
Subs will require different volumes for optimal sealed vs ported
Example
A single 12 may need 1cf sealed or 2cf ported (roughly)
This will change on different woofers
Old 02-10-2015, 04:59 PM
mega fatty
0/11 sssss6008
You can take that 1cf box slap a port externally and it will play but it will be far from an optimal box
Old 02-10-2015, 05:00 PM
tntahoe's Avatar
0/11 sssss1196
Hmmm the company doesnt give any box design specs.
Old 02-10-2015, 05:29 PM
0/11 sssss1882
What sub is in question?
Old 02-10-2015, 05:33 PM
tntahoe's Avatar
0/11 sssss1196
American bass xd8, I just bought a pair and was thinking about trying to run them sealed, but not sure how they will perform versus a ported application. Space will be very limited, as these will be going in a 2010 RAM under the rear seats.
Old 02-10-2015, 07:38 PM
Those look pretty good in about 1-2 ft^3 sealed, or about 2 ft^3 ported in the mid 30's. Attached is a comparison of a few enclosures. 0.5 sealed is a little anemic on the low end, 2 sealed is much better if you have the room. Vented will give you about a 3dB boost between 35-60hz on the same power. I used 500 watts for this model even though your power may be different. I modeled a few smaller vented boxes but the ports will get really complicated and the response doesn't look great.
Old 02-10-2015, 09:14 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Why doesn't AB provide any box specs??
I know they're good but that has me questioning them on that.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 02-10-2015, 09:44 PM
tntahoe's Avatar
0/11 sssss1196
For now I plan on using an MB Quartz ONX 1.1000D. Can you explain to me what the middle graph represents? Also where did you get the t/s parameters from, they look different than what AB has on their site.
They have a couple box designs for like 3 of their subs but not all of them which is odd.
sub comparison d2freak82 General Car Audio Discussion & Questions 8 05-09-2013 10:20 AM
Box Question. RE box calculator ianlahood13 Enclosure Discussion & Design Construction Help 1 06-06-2011 12:23 AM
Sub Box question. I r box nub. MisterTedster General Car Audio Discussion & Questions 2 10-03-2010 09:32 PM
box question (NOT A DESIGN QUESTION) highpsicobra General Car Audio Discussion & Questions 0 07-15-2010 02:10 AM
comparison montr2229 (PSI Car Audio) 8 06-16-2010 03:17 PM
