Box for a single 12" FU Audio 750 - D2 help? - Car Audio Classifieds!
Old 02-11-2015, 12:03 PM
randombeat's Avatar
0/11 sssssss60
Default Box for a single 12" FU Audio 750 - D2 help?
Specs:
12 sub
Recommended enclosure info:
Sealed ~ 1.0 to 1.5 ft^3
Ported ~ 1.75 to 2 ft^3 @ 32 to 35 Hz
FU750-12"
Re: 4.0 Ohm
Fs: 33 Hz
Qms: 5.21
Qes: 0.56
Qts: 0.51
Vas: 34.4
Le: 4.36 mH
BL: 21.3
SPL: 88.2dB
Sd: 490 cm^2
Mms: 243.1 g
Xmax: 20mm
Going into a 91 honda accord wagon, would prefer something wide and somewhat shallow, so the wife could still get groceries and such....
have around 35" width to work with, and prefer under 15" high if possible...
Any help guys?
Old 02-11-2015, 12:53 PM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
What's your question?, besides 'any help guys'....
Sent From Oklahoma
Old 02-11-2015, 02:17 PM
randombeat's Avatar
0/11 sssssss60
If anyone could help me with a design, and/or has any experience with that particular sub and what it does well in (box wize)?
Old 02-11-2015, 03:07 PM
e2theloc's Avatar
0/11 ssssss909
how much power will the sub be seeing? what frequency range do you want it to perform best at?
150+ Club
Follow me on Twitter!! @e2theloc
Old 02-11-2015, 05:31 PM
randombeat's Avatar
0/11 sssssss60
800rms, i listen to hip hop, drum and bass, and some classic rock. looking for daily, most musical but with authority...
JL Audio 6W3v3-4 1-Way 6.5" Car Subwoofer Sub Mid Bass Single 4 Ohm Original Box mizatt32 eBay 0 07-09-2014 08:21 PM
Box for Single DC Audio 8 lvl 2 Alek17 Enclosure Discussion & Design Construction Help 3 10-18-2012 09:12 PM
Single Sundown Audio 10" Z Box Ami Creations General Car Audio Discussion & Questions 4 12-18-2010 06:40 PM
Memphis Audio 12" Ground Shaker Single Port Box bwe45 Wiring, Electrical & Other Installation Equipment 8 08-18-2010 11:06 AM
Single 12" sub in good box vs. 2 12" subs in box that's a little too small? MisterTedster General Car Audio Discussion & Questions 6 01-07-2010 01:01 AM
