2 RE Audio REX10 Daily Box Suggestions - Car Audio Classifieds!
Old 02-15-2015, 08:45 PM
jonnyv713's Avatar
0/11 sssss1090
Default 2 RE Audio REX10 Daily Box Suggestions
I got these little RE Audio REX10s for basically nothing for my daily ride. I don't have a lot of experience with 4th orders, but do you guys have any suggestions on using one with these subs, or would I have better luck with a regular ported enclosure? They might have a bit too low of Qts for a 4th, but idk?
here are the specs.. I have 2 of them with a little 600RMS amp. I listen to mostly rap, so lows are wanted mostly.
Electrical Q Value -Qes: 0.39
Mechanical Q Value -Qms: 4.37
Total Speaker Q Value -Qts: 0.36
Free Air Resonance -Fs: 21.5 Hz
Equivalent Compliance -Vas: 75.6 liters
One-Way, Linear Excursion -Xmax: 12 mm
Efficiency -SPL 1W/1m: 84.7 dB SPL
Effective Piston Area -Sd: 322 cm^2
DC Resistance -Re: 3.2 ohm
Nominal Impedance -Znom: Dual 4 ohm
Thermal Power Handling -Pe: 175 W
Force Factor -Bl: 15.4
Old 02-16-2015, 04:50 PM
jonnyv713's Avatar
0/11 sssss1090
Also have an Alpine Type X I could play around with.. I just really wanna try a 4th order to blow through the ski pass
XFL Daily box suggestions??? tez4life General Car Audio Discussion & Questions 2 02-28-2014 09:31 PM
3 re audio se 12s box suggestions? little red General Car Audio Discussion & Questions 4 03-11-2013 12:51 PM
best ported box for daily?? hughesc9393 General Car Audio Discussion & Questions 6 07-17-2011 04:58 PM
Enclosure build for 2 RE Audio REX10 BKNIGHTS Build Logs 5 02-25-2011 09:29 PM
HDC10's daily box oslouie General Car Audio Discussion & Questions 16 11-20-2010 09:36 PM
