4 SA 10s d2 in 4th order - Car Audio Classifieds!
Old 02-25-2015, 10:16 PM
0/11 ssssss133
Red face 4 SA 10s d2 in 4th order
im needing some help with coming up with a 4th that will do decent numbers but also play low say maybe 28hz-42hz. It's my understanding a large ratio like 1:4 will provide a higher score with proper tunning but a lower ratio can be used better for a daily set up. I have 41 cubic feet to use. Just putting it out there as a starting point lets use 4 cubes for the sealed and 16 cubes for the ported 12 sq of port per cube.
What do yall think. Input? Suggestion? Oh and I will have 5k on tap to use.
Thanks
Old 02-25-2015, 10:23 PM
0/11 ssssss133
Also failed to mention that I have a single cab 97 Chevy 1500. It will be a rear window blow through.
Thanks
4th order for 4 sa 10s littleharv93 (Sundown Audio) 6 08-16-2012 01:44 PM
4th order for 4 l7 10s jorgesau100 Enclosure Discussion & Design Construction Help 0 03-27-2012 12:40 AM
2 10s 4th order, 08 galant RidnClean Build Logs 53 07-19-2011 05:44 AM
4th order for 6 sa 10s 99Bonney Enclosure Discussion & Design Construction Help 12 07-18-2011 08:26 PM
2 4th Order 10s D4 GearGuy2001 Wanting to Buy (WTB) 10 07-05-2010 08:31 AM
