Threaded Inserts - Car Audio Classifieds!
Old 03-02-2015, 07:23 PM
0/11 sssssss29
Default Threaded Inserts
I was thinking about using Threaded Metal Wood inserts to secure my subwoofers with Cap Bolts. I do not want to use H or T nuts, I want to use the threaded style.
What type of glue or adhesive would you suggest for securing them into the enclosure. It is made of 3/4 MDF
Thanks
Old 03-02-2015, 07:35 PM
0/11 sssss2011
Feedback Score: 61 reviews
i personally use a medium consistency CA glue if I use T-nuts or threaded inserts in wood.
Old 03-02-2015, 07:38 PM
0/11 sssssss29
Yea, I was a little worried about the shear strength of CA?
What size of insert do you use ?
Old 03-02-2015, 08:41 PM
hnnnnggg
0/11 sssssss79
I use t-nuts, and use PL premium glue to secure them to the baffle. Never had an issue with one backing out or spinning.
I've seen people suggest Fasco #110 for strength when bonding un-like surfaces, but I always have PL on hand so just use that.
Same stuff should work for threaded type. Any reason you prefer threaded over t nuts? Are you using MDF or Ply?
Old 03-02-2015, 08:55 PM
0/11 sssssss29
I'm using MDF, Threaded Inserts seem like they would be less problematic than T or H Nuts
Old 03-02-2015, 10:12 PM
hnnnnggg
0/11 sssssss79
That's probably just fine then, I used threaded inserts once on MDF and they came out great.
Only complaint I've seen personally on T-nuts if that they are finnicky in MDF.
I would pre drill for the insert and lay some PL/Fasco/Whatever you come up with in the hole, sink your insert and call it a day.
When everything is wired up and working well, I go back coat the screws with some blue threadlocker so they don't turn themselves out of the inserts over time.
Old 03-02-2015, 10:21 PM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
IMO it's not worth the risk. But to each his own. After having a couple T nuts back out I wrote that off permanently.
Current Build:
#60sHereIcome
Old 03-02-2015, 10:24 PM
hnnnnggg
0/11 sssssss79
It would suck if I had a t-nut fail in some way. I would basically be up shit creek since they're 1/4" t-nuts and bolts, so keep that in mind.
Old 03-02-2015, 10:37 PM
0/11 sssssss29
I'm not using T nuts, I am going to use externally threaded inserts for wood, the hex style like EZ LOK or the round slotted brass style
Old 03-02-2015, 11:00 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
No one mentioned spiked T-Nuts?!
Currently using these in my box and trust me, you'd have to strong hold or turn to twist them...but I doubt it since they're a pretty big in size.
now the regular t-nuts I agree. Those suck and don't stay put once you put the sub in and find out the t-nut is sitting on the bottom of the box and you gotta pull the sub out.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
reupholstering car seats, Thinking black swade with yellow inserts. davidrforbus General Car Audio Discussion & Questions 0 06-10-2012 11:02 PM
FS: Cobalt fiberglass door inserts Bushj311 Wiring, Electrical & Other Installation Equipment 11 05-21-2012 02:21 PM
New Door Inserts Bryan Member Rides & System Pictures 15 05-08-2010 12:44 PM
Infinity kappa perfect 10dvq adjustable q inserts Palos Wanting to Buy (WTB) 0 04-24-2010 06:27 PM
How to make 45 Degree Inserts (Vented boxes) wasted ink Tutorials & Quick References 2 11-27-2008 02:41 PM
