Quick round port question, please help thanks. - Car Audio Classifieds!
Old 03-05-2015, 03:28 PM
oxsign's Avatar
0/11 sssss1876
Default Quick round port question, please help thanks.
Box is 49.5"W x 20.5" T x 24"D (roughly 11.8 cube gross) with 2 15"s (.36 displacement). I have some 8.5" Sono tube sitting here and was thinking of using it as a port for this box. Ideal tuning would be 28Hz-30Hz, how long would I need it? I have 8" from the face of the box to the back of the seat of some needs to be external.
Thx for the help guys.
1971 VW Fastback
Old 03-05-2015, 04:40 PM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
You wanting to only run 1 of them? I'm running 2 8.25" sono tubes for my ports in 11 cubes net tuned at 25hz.
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 03-05-2015, 04:47 PM
SPL Farms
0/11 sssss5706
The answer is with 2 20" long gets you to 32hz 24"gets you to 30, 31"gets you to 28 if all internal. If doing say 4" external with dual ports just add half a cube back to the enclosure volume and calculate for a fully internal port length. So with 4" external you'd be at 28hz with 28" of length with 2 8.5 sono tubes.
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
The Following User Says Thank You to e46inperrycounty For This Useful Post:
oxsign (03-10-2015)
oxsign's Avatar
0/11 sssss1876
I'm not against it at all. What leignth for 2 @ 29Hz??
1971 VW Fastback
Old 03-05-2015, 04:49 PM
oxsign's Avatar
0/11 sssss1876
Awesome info, thank you. 👍
1971 VW Fastback
Old 03-05-2015, 05:08 PM
SPL Farms
0/11 sssss5706
25" total length with 4" external and 2 8.5 sono tubes is 29hz
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
oxsign (03-10-2015)
Old 03-10-2015, 08:34 AM
1loudmonte's Avatar
Team Incriminator Audio
0/11 sssss2167
Feedback Score: 36 reviews
You definitely want 2 8" aeros/sonotube ports at a minimum for 2 15s. That gives you a decent amount of port area.
(2015 MECA Street 3 World Champion)
2004 Dodge Ram Single Cab 1500
3 Incriminator Audio Judge 15s
3.25:1 Ratio 4th Order Blowthrough
1 x AA 9.0 TFHE, 2 x AA 150.4
4 X Crossfire XS-M8's, 2 x PRV Tweets
quick port area question slamica General Car Audio Discussion & Questions 2 02-03-2012 06:25 PM
quick aero port question quaddropper General Car Audio Discussion & Questions 3 04-23-2011 10:52 AM
round port question joselito318 General Car Audio Discussion & Questions 0 11-04-2010 09:16 AM
Need some quick help please!! port question beany Enclosure Discussion & Design Construction Help 7 06-16-2010 05:11 PM
quick aero port question blazron22z Enclosure Discussion & Design Construction Help 9 01-25-2010 12:01 PM
