Tips on building box in trunk - Car Audio Classifieds!
Old 03-16-2015, 08:54 PM
crownvicon26's's Avatar
0/11 sssss1882
Default Tips on building box in trunk
As the title states, what are some of you guys methods of doing this?
Taramps 8k
2 Zv.3 15's
2.87:1 4th Order @ 48hz
Old 03-16-2015, 08:56 PM
0/11 sssss8594
Feedback Score: 55 reviews
pocket jig
Enclosures
Old 03-16-2015, 09:01 PM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
Plan, plan, plan, and then plan more... you have to plan each screw in each piece so you don't end up not being able to screw a section half way through the build and end up having to rip it out and start over. If you use a kraig jig it makes it much easier. If you are going old school then you have to plan your cut sheet around what piece can be screwed. Like don't have the top sit on top of the sides and front/rear if you can't screw it to the sides/front/rear. Get a 90 driver bit, those things are a life saver!! I put my screwgun in every position I would need to screw from to ensure I could fit it in there and apply enough force to get the screw in.
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 03-16-2015, 09:52 PM
Todd Dupler's Avatar
Team SPL Farms
0/11 sssss5000
Impact rated right angle drive, a couple long extensions and a bunch of aluminum angle.
01 Volkswagen Golf 2 door
Kenwood ddx470
Old 03-16-2015, 09:58 PM
Hdorre's Avatar
0/11 ssssss540
i dont know how i couldve build my old box in my trunk without my kreg jig.
Old 03-17-2015, 04:18 PM
0/11 sssss1882
Thanks guys. Kreg jig it is. Already have a 90 degree drive. That thing is a life saver. Which one should i get exactly?
Taramps 8k
2 Zv.3 15's
Building box in sealed off trunk question Ian87 Enclosure Discussion & Design Construction Help 13 02-22-2014 06:56 PM
any tips when building a box to get it louder to the ear then the meter? massivespl General Car Audio Discussion & Questions 80 10-28-2012 10:52 AM
Box Building Help/Tips Bologna General Car Audio Discussion & Questions 15 12-02-2011 05:59 PM
Building box in trunk: Tips Drillrig52 Enclosure Discussion & Design Construction Help 9 11-20-2011 12:22 AM
anybody got any tips for building a box in the trunk Craig28 Enclosure Discussion & Design Construction Help 11 05-05-2011 11:27 PM
