box 4 DD 712s help - Car Audio Classifieds!
Old 04-07-2015, 01:48 PM
0/11 ssssss339
Default box 4 DD 712s help
I made a box for behind the seat of my truck its like a huge truck style box 59 wide 28 high 12 btm and 8 top, I calculated it was 7.7ft and went with 3x 4" aeroports. I ended up putting 4 12s in there then realized that every sub needed a port,I should have done 4x ports?? each port is 11" long i think im low 30s htz? my issue some songs sound decent and others like crap,and even with the decent songs the subs begin to smell a bit. Im running a Sundown 3500d each 12 is 1200w rms im wired 1 ohm. DO i need the 4th port??
Old 04-16-2015, 10:01 PM
0/11 sssssss65
If you could fit It would try 3 6" ports at about 24 inches. Would put you at 32 hz they would stick out just a lil but would give you right around 11 per cube. I'm sure there's some much more experienced and more knowalgble people that could help more put 9-12 is a good port per cube for round/aeros. Just a quick rule but read Nissanbassheads post on theile small specs. A ton of amazing info. Seems like a lot to take in but really helps out.
Old 04-30-2015, 02:07 PM
0/11 ssssss339
I cant fit 6" ports Im just going to re do the box i might just throw my 2 DD9515s in there with a new box
Old 04-30-2015, 02:26 PM
0/11 sssssss65
Yeah i had to do extended 6" aeros to make it work in my truck.
Old 04-30-2015, 02:32 PM
0/11 ssssss339
this was my second box ever with aeros I dont know if i like them i havent had good luck
Old 04-30-2015, 02:41 PM
0/11 sssssss65
Ok yeah I like em quite a bit. They are perfect if you don't have a lot of space. U can use pvc I shoot for at least 10 in per cube with aeros
Old 04-30-2015, 03:51 PM
0/11 sssssss65
And also you don't really have to have one per sub 1 6" is more efficient than two 4s. Two 4" is 26" of port are and 1 6" is 28" of port area. I had 4 sundown 8s in a 3 cube box with one 6" aero and it pounded. With the box you had you had about 6" per cube of port. Just trying to help with some info.
Box choice 4th order or big ported box in Cadillac dirtysouth basshead Enclosure Discussion & Design Construction Help 12 02-09-2015 12:52 PM
Default Box choice 4th order or big ported box in Cadillac dirtysouth basshead General Car Audio Discussion & Questions 5 12-18-2014 04:58 AM
Need you guys help with box four sundown zv3 18s ported box 12k rms. Mnorwood01 (Sundown Audio) 56 04-08-2013 05:38 PM
18" trunk box dual corner loaded square port box Jacobbz206 Enclosure Discussion & Design Construction Help 0 06-20-2010 06:53 AM
